iPAD Panotour viewer   [SOLVED] - View the solution
Mike Spence
by Mike Spence » Mon Aug 18, 2014 1:32 pm
I have uploaded a number of Panotour tours which all work well on PCs or MacBook viewers. However on the iPAD these tours all appear very poor resolution and results in me avoiding the use of these tours on iPADs when demonstrating these to potential clients (unless they are full 360 degree spherical images).
Why is this and is there a fix?
thanks
Mike
Re: iPAD Panotour viewer
by mediavets » Mon Aug 18, 2014 1:52 pm
Mike Spence wrote:I have uploaded a number of Panotour tours which all work well on PCs or MacBook viewers. However on the iPAD these tours all appear very poor resolution and results in me avoiding the use of these tours on iPADs when demonstrating these to potential clients (unless they are full 360 degree spherical images).
thanks
Mike
It believe it's because multi-res on HTML5 is only supported for full spherical panos.
AFAIK there is no 'fix'.
See: http://www.autopano.net/wiki-en/action/ ... player_.3F
by AlexandreJ » Mon Aug 18, 2014 4:19 pm
There is a trick in panotour that allows to export all tiles for mobile too, but that means that you can pan and see black zone in case of partial panorama. I don't know the trick, but Gerald does. Need to wait for him to finish his holidays.
Likes: 14 posts
Re: iPAD Panotour viewer  [SOLVED]
by bdd » Mon Aug 25, 2014 12:56 pm
As Alexandre said, there is a trick that allow PTP to export partial panoramas as if they were full spherical ones.
That means that many many extra black tiles will be generated.
So the generated tour can be a heavy one.
Once the tour is built you cannot delete all the black tiles, because some of them are loaded even if they are not displayed.
Here is the trick :
On Windows :
1 - Close PTP
2 - Open the registry (with the command line regedit)
3 - Find "Panotour Pro 2.5" under HKEY_USERS/[...]/Software/Kolor
4 - Then open the "application" subdirectory
5 - There find the "internal" parameter. Its value is 0x00000000
6 - Change the value to 0x00000001
7 - Start PTP
On MacOS :
1 - Close PTP
2 - In the Finder open the "Goto" menu
3 - Press "Alt" key, a new menu will appear : "Library"
4 - Click on this menu
5 - Step into the "Preferences" sub directory
6 - Find the files "com.kolor.panotour.*"
7 - Open the files with a plist editor like XCode
8 - Modify the value of "internal" parameter. Set it to "1"
9 - Start PTP
Edit (26/09/2017): Updated information for changed registry key name and location.
by mediavets » Mon Aug 25, 2014 1:05 pm
bdd wrote:As Alexandre said, there is a trick that allow PTP to export partial panoramas as if they were full spherical ones.
Here is the trick :
On Windows :
1 - Close PTP
7 - Start PTP
On MacOS :
1 - Close PTP
9 - Start PTP
And what is the result/benefit of this 'trick'?
Likes: 14 posts
by bdd » Mon Aug 25, 2014 1:20 pm
mediavets wrote:And what is the result/benefit of this 'trick'?
To have multiresoltuion on partial panoramas on tablets and phones.
by mediavets » Mon Aug 25, 2014 2:53 pm
I am confused now.
Does the reg. edit of the 'forcefull' parameter that you propose mean one no longer has to render the partiial pano as a full 360x180 and suffer the overhead of all those redundant black tiles?
Likes: 14 posts
by bdd » Mon Aug 25, 2014 3:00 pm
I am confused now.
If you set the forcefull parameter to 1, PTP will generate extra tiles for partial panoramas, and they will be considered as full spherical ones in the player.
But they will be cropped.
So on tablets or phones, you will have the benefits of multiresolution, that is currently supported only on full spherical panoramas, but many unnecessary black files which basically comes down to the same as force rendering your panorama as 360x180°, resulting in much larger tours.
Mike Spence
by Mike Spence » Sun Aug 31, 2014 7:25 pm
So does this mean that creating a (non spherical) hi res cylindrical panorama for use on an iPAD is not going to work without a black background? Or is what you are suggesting that they will be cropped but the images will be prohibitively large file sizes?
thanks
Mike
by mediavets » Sun Aug 31, 2014 8:17 pm
Mike Spence wrote:So does this mean that creating a (non spherical) hi res cylindrical panorama for use on an iPAD is not going to work without a black background? Or is what you are suggesting that they will be cropped but the images will be prohibitively large file sizes?
thanks
Mike
I believe he means the latter.
Panogold
by Panogold » Tue Sep 02, 2014 4:25 pm
Hi Mike
please have a look at this http://panogold.de/311/
"Tour-1" is limited and has no zoom. It works fine on a iPad.
"Tour-2" is zoomable and works in multiresolution on PC and Safari, but not on iPad!
When you zoom "Tour-2" on an iPad you get a horrible pixeled picture.
Martin
by benji33 » Wed Sep 03, 2014 10:53 am
Do you use this trick ? http://www.kolor.com/forum/viewtopic.php?f=97&t=23360#p147679
It seems it's not the case.
Because partial panorama are only displayed in Mono-resolution on iPad by default.
So if you zoom on a mono-resolution panorama, the image resolution doesn't change and it's blurry.
