Panotour Viewer Not Responsive
mdbarnes13
by mdbarnes13 » Fri Aug 15, 2014 2:52 pm
I downloaded Panotour Viewer for my Windows-based PC. When I open the program and try and load a tour, it does nothing. Furthermore, the Viewer requires a ptv file and I see no options for this type of export from PTP2. Can it open a .kpt file?
Any suggestions would be appreciated.
Thanks.
Re: Panotour Viewer Not Responsive
by mediavets » Fri Aug 15, 2014 3:15 pm
mdbarnes13 wrote:Hello,
Thanks.
No, it cannot open a KPT file.
You can specify to output a PTV file in the Build options.
You need to be using PTP 2.2 (or later).
