Custom HTML Template feature is not included in the Viewer..
by Destiny » Sat Aug 02, 2014 8:18 am
Hi...
Is there anyway to include custom HTML template features into the viewer...
Re: Custom HTML Template feature is not included in the View
by mediavets » Sat Aug 02, 2014 8:37 am
Destiny wrote:Hi...
What did you have in mind?
by Destiny » Sat Aug 02, 2014 8:39 am
Well...
My custom template which has my Contract will not work.. It works as HTML but not with the Viewer... I am sure the CSS is missing in the Viewer but fine in the HTML....
Likes: 14 posts
by bdd » Sat Aug 02, 2014 8:59 am
Destiny wrote:Well...
Hi Destiny,
If your HTML template uses some extra files, PTP does not know them, except if they are in the template subdirectory.
In your HTMLL template directory, if you have a HTML template called myhtmltemplate.html; then all the files found in a directory called the same way : myhtmltemplate will be included too in the tour, and in the PTV file.
So if your HTML template uses some CSS files, you should set them in this subdirectory.
by Destiny » Sat Aug 02, 2014 9:19 am
Thank you Gérald
I will test that out..
by Destiny » Sun Aug 03, 2014 7:30 am
Not sure if its possible Gérald..
My Contact also needs a mail.php, images, and css as well as js.. I have tried creating a subfolder with src to those.. it shows to work in the Template but not in the build and not in the Viewer.. I have been just adding these files into the main folder after the build.. I never found a way of auto magically adding the files..
by benji33 » Tue Aug 05, 2014 10:56 am
.php file will never work. PT Viewer can only serve for the moment .html/.htm file
by Destiny » Tue Aug 05, 2014 11:38 am
Thank you Benjamin....
I guessed as much... ;)
