Viewer on Vista?
flyeye
Viewer on Vista?
by flyeye » Tue Jul 29, 2014 10:52 pm
does somebody knows if the viewer also works (or not) on a Vista machine. I have a customer by which the viewer is not working. Thanks for your answer/solution.
Likes: 14 posts
Re: Viewer on Vista?
by bdd » Wed Jul 30, 2014 8:27 am
flyeye wrote:Hello,
We did not check Panotour Viewer on Windows Vista.
Windows Vista is not supported anymore by Microsoft, so if the bug is linked to this version of Microsoft, we will probably not fix it.
Does someone here still have this Windows version and can test Panotour Viewer on it ?
by mediavets » Wed Jul 30, 2014 8:43 am
bdd wrote:We did not check Panotour Viewer on Windows Vista.
It appears that Vista is still supported?:
http://www.neowin.net/news/windows-vist ... ed-to-2017
Likes: 14 posts
by bdd » Wed Jul 30, 2014 8:46 am
mediavets wrote:It appears that Vista is still supported?:
Extended support only, yes.
flyeye
by flyeye » Wed Jul 30, 2014 2:14 pm
problem (of mine) is solved. Customer has purchased a new laptop :lol:
Regards,
Henk
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Wed Jul 30, 2014 7:23 pm
PTViewer works absolutely fine for me on Windows Vista 32bits, albeit a bit slowly. That could of course be cause by the fact that I abandonned this computer and got a new one ;D
flyeye
by flyeye » Wed Jul 30, 2014 7:31 pm
Thanks, good to know :)
