A bug with multi-level floor maps while changing languanges
Kizek
by Kizek » Mon Feb 05, 2018 7:27 pm
There is an issue with PTP where a multi-level floor map is changed to a single floor map when vtour language is changed.
A link with the example is on the url <https://www.euroart93.de/temp/ptp/>.
Does anybody knows how to solve this error?
Re: A bug with multi-level floor maps while changing languan
by Annis » Tue Feb 06, 2018 11:30 am
Indeed that looks like a pretty nasty bug. I'll file a report, thank you.
Kizek likes this post.
Kizek
by Kizek » Tue Feb 06, 2018 10:03 pm
Thank you Annis.
I hope that you'll fix this bug ASAP or help me in any other way, like with external script maybe.
by Annis » Wed Feb 07, 2018 11:00 am
I asked the devs if there's a workaround or edited file we can give you as a temporary workaround but I'm still waiting on an answer.
Kizek
by Kizek » Tue Mar 06, 2018 1:32 pm
Hi, any news on this?
by benji33 » Wed Mar 07, 2018 9:46 am
You can try this edit in attachment to replace your KolorArea.min.js file into the YOUR_TOURdata/graphics/KolorArea directory.
This will be solved into the next Panotour Pro release.
KolorArea.min.js.zip
(3.23 KiB) Downloaded 182 times
Kizek
by Kizek » Mon Mar 12, 2018 8:46 am
Hi benji33,
Thank you for your help!
Unfortunately, problem still remains after 'KolorArea.min.js' file replacement as you can check on the given URL link
by benji33 » Tue Mar 13, 2018 5:17 pm
Ok not suffisent.
Open for edit the test_skin.xml file then find and replace these lines
js(invokePluginFunction(floorPlan, changeLanguage));
js(invokePluginFunction(floorPlanArea, changeLanguage, false));
by these ones
js(invokePluginFunction(floorPlanArea, changeLanguage, false, false));
Kizek
by Kizek » Wed Mar 14, 2018 8:54 am
Hi benji33,
This is it :) well done and thank you very much. You can check it on the given url link.
Bye!
