Page 1 of 2
Panotour 2.3 crash
PostPosted: Fri Dec 05, 2014 12:25 pm
by marbotrade
I downloaded to try Panotour Pro 2.3 on 32
Want to load a panorama. It loaded.
But when click on panorama to work with it, crash; the panotour shut down...no message, nothing.
For 32 don't works?
Tks
Re: Panotour 2.3 crash
PostPosted: Fri Dec 05, 2014 12:45 pm
by benji33
Your graphic card drivers are up-to-date ?
And can you please validate the following test ?
1/ Open Panotour Pro 2.3
2/ Close Panotour Pro 2.3 (this Open/Close will force creation of registry parameters)
3/ Open the registry using command "regedit"
4/ Find the key named "HKEY_USERS\[...]\Software\Kolor\Panotour Pro 2.3\view\3d_autoload"
5/ The value of this key is set to "true". Double click on it and set it to false.
6/ Then re-start PTP
The 3D view of the selected panorama will be black and will contain a button asking if you want to load the 3D view.
Click on this button, and tell us what happens then.
PostPosted: Fri Dec 05, 2014 1:35 pm
by marbotrade
First I will make an update to driver video.
Second will make the test with regedit.
Tks
PostPosted: Fri Dec 05, 2014 1:49 pm
by marbotrade
I made all you saied.
Same result.
In regedit the value=false. When load a panorama, the panorama it look normal. But, when click on it to work with it, bluf....the panotour shut down...
PostPosted: Fri Dec 05, 2014 2:02 pm
by bdd
Sorry, I am not sure to understand.
You set "3d_autoload" to false, and you were not able to select a panorama ?
Did you really close Panotour before modifying the registry ?
Panotour Pro should be closed before doing it.
3d_autoload set to false, should disable the 3D view and so allow you to skip the crash that happens on it.
It does not fix the crash, it just avoids it.
PostPosted: Fri Dec 05, 2014 2:28 pm
by marbotrade
3d ...autolaod
Hi again,
See in attach how is 3d Autoload...
PostPosted: Fri Dec 05, 2014 2:37 pm
by marbotrade
...here is the panorama loaded.
But if I will click on it, to work it, all shut down.
PostPosted: Fri Dec 05, 2014 2:38 pm
by bdd
Can you then re-upload a crash report?
And please fill the email field of the crash reporter window.
Your first report indicated that the crash occured while displaying the 3D view. Maybe this crash is another one.
PostPosted: Fri Dec 05, 2014 2:39 pm
by marbotrade
"Can you then re-upload a crash report?"
None crash report was made...nothing..just close the screen
PostPosted: Fri Dec 05, 2014 2:50 pm
by benji33
What was your latest working PTP version on your 32bits computer ? thanks
PostPosted: Fri Dec 05, 2014 3:07 pm
by marbotrade
Was 2.0
Delete entire line 3d_autoload from regedit, same result: will cose instant the PTP file
PostPosted: Sat Dec 06, 2014 4:51 pm
by sandor
Version 2.2 works flawlessly, but the v.2.3 of the same error occurs as indicated by 'marbotrade' !!!
PostPosted: Sat Dec 06, 2014 10:01 pm
by marbotrade
Sandor, have right.
Version 2.2 Panotour Pro 32 works fine!
PostPosted: Mon Dec 08, 2014 11:32 am
by benji33
Thanks for this verification sandor and marbotrade. A report has been added. If needed more questions will be added here.
PostPosted: Wed Dec 10, 2014 12:22 pm
by marbotrade
Fine.
We will waiting...
PostPosted: Sun Dec 14, 2014 12:36 pm
by Aigles immobilier
Je viens d'acquérir la dernière version de Panotour pro et j'ai exactement le même problème.
Dès que je clic sur un panorama, Panotour se ferme.
PostPosted: Sun Dec 14, 2014 7:15 pm
Re,
Pour donner suite à mon précédent message.
Configuration :
Win 7 -32 bits
Intel core 5i 3.3 Ghz
4 go de ram
carte graphique radeon 5700 hd
En complément, voici un fichier reprenant l'exécution de panotoupro 2.3
PostPosted: Thu Dec 18, 2014 10:57 am
by benji33
Is it possible to make this test on you 32bits PC ?
- Open PTP 2.3
- Load a panorama and don't click on it.
- Save project as "testProject.kpt"
- Close PTP 2.3
- Open regedit and go to the HKEY_CURRENT_USER/Software/Kolor/Panotour Pro 2.3/view/
- double click on 3d_autoload and set it to false value
- Close regedit
- Load the "testProject.kpt" file and once loaded click on the panorama.
Is it working ?
PostPosted: Thu Dec 18, 2014 12:32 pm
by sandor
I did it , but the same result!
PostPosted: Thu Dec 18, 2014 12:55 pm
by benji33
Thanks for your report, because on my win32 bits Vitual Machine this trick works to bypass the problem.
PostPosted: Thu Dec 18, 2014 10:07 pm
by CamDog
Hi there,
basically I work on my tour at my office PC, but when I tried to do some tests during the evening at home I ran into the same troubles: PTP2.3 works fine on 64Bit (Windows 7 Home Premium, 12 GB RAM) but crashes on 32Bit (Windows Vista Home Premium, SP2, 4 GB RAM) with the same project: all you need to do is to open a project an click on a panorama.
What I figured out by now is that this happens only when the "Properties" window is open. So closing the "Properties" window before you click on the panorama will avoid that crash and you can at least use the Hotspot-Editor. But in the moment you try to reopen the Properties window via the menu bar PTP crashes again. So it looks to be a bug somewhere in the Properties window.
I got no option to create or save a crash report, only a Microsoft Windows MessageBox tells me "Panotour Pro does not work anymore". After confirming that MessageBox a Windows System Tray notification appears telling me that PTP was closed by the Data Execution Prevention to ensure safety for the PC.
And finally, look how weird the Property window looks like right after the crash (see attchment).
Furthermore, the same kind of crash occures after you added a Simple Button. The moment you try to set the Action for this button to "Basic.Go to panorama/group" PTP dies. All other Actions might be chosen without crash, I have tried all of them.
Last but not least, I also executed the test sequence you described for marbotrade at the very beginning of this thread (3d_autoload=false) but neither this worked for me: PTP crashed the same way as described above and reported by the others.
My only installed version of PTP is this v2.3, but I have Autopano Giga installed in versions 2.5, 3.0 and 3.5
If you need some further tests to be done you can address me.
Cheers from Vienna,
Rob
PostPosted: Fri Dec 19, 2014 3:36 pm
by benji33
Thanks. In fact the problem seems to be the 3D preview into properties, but the trick should solve the issue so we are investigating on the whole problem.
PostPosted: Mon Dec 29, 2014 8:23 pm
by chris87
Exactement le même problème !
Windows 7 32 bits Sp1 - Drivers carte graphique à jour-
PostPosted: Fri Jan 02, 2015 9:35 am
by benji33
Merci Chris, nous travaillons à la résolution de ce problème sur plateforme 32 bits.
PostPosted: Tue Feb 17, 2015 12:41 pm
by popeye
Hello.
The same problem, sometimes even throws on loading photo.
Dear Kolor team. Is there progress?
