Global Viewer folder
Michael Ezra
by Michael Ezra » Thu Aug 16, 2018 2:54 pm
The data directory of the rendered tour contains folder /graphics with about 500 files.
When hosting numerous tours this adds up and this folder is duplicated (and shared hosting plans have limit on number of hosted files). Is there any way to avoid such duplication and utilize a global folder shared for all tours?
This may be related, I am using PanoPress plugin to embed the tours into web pages.
PanoPress points to a global viewer: http://www.panopress.org/example/global-swf-krpano
Are there more descriptive instruction how to set this up? I have a license for Panotour Pro, no additional liceses for krpano.
Thanks!
Re: Global Viewer folder
by benji33 » Fri Aug 17, 2018 12:44 pm
If resources are the same or with differents name, it's possible to merge the directories. Once done you'll have to edit all xml files to reach the right merged "graphics" directory and not the default one.
Michael Ezra
by Michael Ezra » Fri Aug 17, 2018 1:01 pm
Can you please be more specific, which XML files?
by benji33 » Tue Aug 21, 2018 1:51 pm
Yourtour.xml , Yourtour_skin.xml , Yourtour_core.xml , Yourtour_vr.xml , Yourtour_skin_vr.xml and Yourtour_core_vr.xml files where Yourtour is the name of the generated tour filled into the Build template.
Michael Ezra
by Michael Ezra » Wed Aug 22, 2018 9:52 pm
Thanks.
Is there a way to utilize the global viewer as PanoPress points out: http://www.panopress.org/example/global-swf-krpano
If not at present, please consider for future releases.
by benji33 » Thu Aug 23, 2018 11:08 am
No sorry you have to update all xml files by hand at this time.
