[RESOLU]Trame sonore qui ne varie pas lorsque l'image tourne   [RESOLU] - View the solution
MackyLuke
by MackyLuke » Thu Jun 05, 2014 9:35 pm
Est-il possible d'utiliser une trace sonore sans que le volume diminue lors de la rotation de l'image?
Merci
Re: Trame sonore qui ne varie pas lorsque l'image tourne
by mediavets » Thu Jun 05, 2014 10:54 pm
MackyLuke wrote:Est-il possible d'utiliser une trace sonore sans que le volume diminue lors de la rotation de l'image?
Merci
Yes, configure the sound as a Background sound in the Panorama properties - rather than setting a (directional) Sound spot.
MackyLuke
by MackyLuke » Fri Jun 06, 2014 12:27 pm
Each soundtrack is attached to a Hotspot. Have a look... http://www.360-image.com/360/helico/
by mediavets » Fri Jun 06, 2014 12:56 pm
MackyLuke wrote:Each soundtrack is attached to a Hotspot. Have a look... http://www.360-image.com/360/helico/
If you attach sounds to hotspots then they will be delivered as directional sounds.
I don't feel that it is a problem in your pano/tour;because you don't use autorotation.
You could edit the XML file to change the directional aspect of the sound.
It would be a good to have that option via the GUI too. You may wish to request that feature in later versions.
MackyLuke
by MackyLuke » Fri Jun 06, 2014 1:17 pm
mediavets wrote:You could edit the XML file to change the directional aspect of the sound.
And what is the variable I could edit in the XML file?
by mediavets » Fri Jun 06, 2014 2:12 pm
Look for the directional sounds section in the tour-name.xml file - see screenshot and edit according to krpano documentation for the sound player:
http://krpano.com/plugins/soundinterface/
MackyLuke
Re: Trame sonore qui ne varie pas lorsque l'image tourne  [RESOLU]
by MackyLuke » Fri Jun 06, 2014 3:27 pm
I changed this...
<action name="onclickspotpoint25">playsound3Dwhenpossible(soundspotpoint25, %$videos_sounds_path%/sounds/_6-variometer.mp3,true,84.551404,21.785760false);displayImage( %FIRSTXML%/spots/_06-variometre-500px.jpg
To this...
<action name="onclickspotpoint25">playsound3Dwhenpossible(soundspotpoint25, %$videos_sounds_path%/sounds/_6-variometer.mp3,false,84.551404,21.785760false);displayImage( %FIRSTXML%/spots/_06-variometre-500px.jpg
Sound is now working as expected. Thanks for your help
