Fichier SWF   [RESOLU] - View the solution
clod
Fichier SWF
by clod » Tue Apr 29, 2014 8:44 pm
Comment ouvrir en local un fichier SWF, lorsque je fais un clic sur l'icône plein écran l'info bulle m'indique "ouvrir le site" et la vue ne s'affiche pas en plein écran, une idée?
Merci de vos réponses.
clod
Ci-dessous copie d'écran
Mac Mavericks 10.9.2
Re: Fichier SWF
by mediavets » Tue Apr 29, 2014 9:50 pm
clod wrote:Bonjour,
clod
See: http://www.autopano.net/wiki-en/action/ ... ur_offline
clod
Re: Fichier SWF
by clod » Tue Apr 29, 2014 10:20 pm
Merci, mais cela ne fonctionne toujours pas.
clod
Re: Fichier SWF
by mediavets » Tue Apr 29, 2014 10:46 pm
clod wrote:Merci, mais cela ne fonctionne toujours pas.
clod
So you have the tour open in PTP and have completed a Build?
Then you view the tour locally using the View last built tour.. button and fullscreens doesn't work?
What browser on which OS?
You cannot view the SWF directly (nor the HTML file) and have tours created with PTP 2.x work correctly - unlike tours created with PTP 1.8 where that did work.
clod
Re: Fichier SWF
by clod » Tue Apr 29, 2014 10:54 pm
clod
So you have the tour open in PTP and have completed a Build?-----> OUI
Then you view the tour locally using the View last built tour.. button and fullscreens doesn't work?-----> OUI
What browser on which OS?-----> MAVERICKS 10.9.2
You cannot view the SWF directly (nor the HTML file) and have tours created with PTP 2.x work correctly - unlike tours created with PTP 1.8 where that did work.-----> OUI
Re: Fichier SWF
by mediavets » Tue Apr 29, 2014 11:01 pm
clod wrote:What browser on which OS?-----> MAVERICKS 10.9.2
And which browser?
Did you choose to create both Flash and HTML5 versions of the tour?
clod
Re: Fichier SWF
by clod » Tue Apr 29, 2014 11:05 pm
And which browser?-----> SAFARI 7.0.3
Did you choose to create both Flash and HTML5 versions of the tour?-----> OUI
Re: Fichier SWF
by mediavets » Tue Apr 29, 2014 11:18 pm
Could you try with a different browser?
clod
Re: Fichier SWF
by clod » Tue Apr 29, 2014 11:26 pm
Could you try with a different browser?----->NON
Re: Fichier SWF
by mediavets » Tue Apr 29, 2014 11:32 pm
clod wrote:Could you try with a different browser?----->NON
Does the fullscreen function work if the tour is online?
clod
Re: Fichier SWF
by clod » Wed Apr 30, 2014 7:16 am
Ce n'est pas pour mettre en ligne, mais seulement en local.
Likes: 13 posts
Liked in: 115 posts
Re: Fichier SWF  [RESOLU]
by bdd » Wed Apr 30, 2014 11:03 am
clod wrote:lorsque je fais un clic sur l'icône plein écran l'info bulle m'indique "ouvrir le site"
Avez vous un logo dans votre visite ?
Où est-il placé ?
clod wrote: et la vue ne s'affiche pas en plein écran, une idée?
Pour que votre visite puisse correctement s'afficher en plain écran, il ne faut pas ouvrir le fichier swf, mais le fichier HTML généré.
Et il faut le faire via un serveur web local.
http://www.autopano.net/wiki-fr/Panotour_-_FAQ_-_Visualisation_hors-ligne
clod
Re: Fichier SWF
by clod » Wed Apr 30, 2014 4:49 pm
Avez vous un logo dans votre visite ?-----> OUI
Où est-il placé ?-----> En bas à droite
[/color]
Et il faut le faire via un serveur web local.-----> cela fonctionne avec Panotour Pro 1.8 pourquoi pas avec la version 2 ?
Likes: 13 posts
Liked in: 115 posts
Re: Fichier SWF
by bdd » Fri May 02, 2014 9:58 am
clod wrote:Et il faut le faire via un serveur web local.-----> cela fonctionne avec Panotour Pro 1.8 pourquoi pas avec la version 2 ?
clod
Re: Fichier SWF
by clod » Fri May 02, 2014 10:29 am
Je dois être nul, car avec la version 1.8 cela foctionne sans faire appel à:
http://www.autopano.net/wiki-fr/Panotou ... hors-ligne
je fait un clic sur le fichier SWF et tout fonctionne, sous 2.1 même avec Krpano Testing Serveur la visite ne s'affiche pas en plein écran, le HTML oui mas le SWF.
clod
Re: Fichier SWF
by mediavets » Fri May 02, 2014 1:17 pm
clod
Correct.
1.8 and 2.1 behave quite differently in this regard.
2.x was a not a simple upgrade to 1.8, it was recoded from ten ground up and many features and functions are implemented differently.
Many 2.x features are implemented with javascript and full functionality requires that the tour is delivered via web server to overcome the security features in modern browsers.
