Possible bug: Custom Krpano code not saved to project file
Rubidze
by Rubidze » Sun Sep 02, 2018 11:26 pm
I have created a custom point style with three actions.
While working with my project in Panotour, everything is ok. Output is generated as expected. When saving the project, closing Panotour and then reopening the project from file, second custom Krpano code is gone.
Likes: 14 posts
Re: Possible bug: Custom Krpano code not saved to project fi
by bdd » Mon Sep 03, 2018 2:18 pm
This is a known issue in the internal mechanism of Panotour Pro.
But in your case, it can be bypassed by using transitions instead of actions.
The 2 krpano actions you are using before the load and after the load of the new scene, can be translated into source transition and target transition.
You can have a look to the "transitions" folder of the Panotour Pro installation directory, to see how transitions are declared, and then you can create your own ones, into the "User directory" of Panotour Pro .
