export/import presets from a other computer   [SOLVED] - View the solution
dlx
by dlx » Tue Aug 07, 2018 9:17 pm
Hi to everybody,
is there anywhere an instruction how I can export and then import saved preset-styles?
BTW: I've bought a license for my laptop and when I then use the programm on the other computer is that possible with this same license? or do I have to buy another license?
Thank You very much... dlx
Likes: 14 posts
Re: export/import presets from a other computer  [SOLVED]
by bdd » Wed Aug 08, 2018 9:38 am
You can use your license on both machines.
Presets are stored in the User directory of Panotour Pro.
Use the menu "Edit/Open user directory" from Panotour Pro.
Copy its content on the other platform.
If your preset uses some resources/files , you'll have to copy the resources on the other device.
dlx
by dlx » Wed Aug 08, 2018 10:21 am
Thank You Gèrald - PERFECT!!!!
