Unexpected Error Occured durng software execution
buscar71
by buscar71 » Fri Aug 03, 2018 6:05 pm
I just bought Kolor Panotour 2,5. I just wanted to make a tour using my panoramas (.jpg). Unfortunately I can not use my soft because all the time Unexpected Error Occured durng software execution appears and it crush my soft.
I use Windows 7 64bits. I would like to add that demo version worked great, there was no problem with that.
Anybody can help?
Best Regards
Przemek
Likes: 14 posts
Re: Unexpected Error Occured durng software execution
by bdd » Tue Aug 07, 2018 10:02 am
1. Did you download the 32bits or the 64bits version of Panotour Pro installer ?
If you downloaded the 32bits version, uninstall it and install the 64bitsversion.
2. Do you have an up-to-date driver for your graphical card ?
Go on the manufacturer website, download the latest version of the driver, install it, and re-try Panotour Pro.
3. Do you have enough memory on your machine ?
Try to change the memory settings of Panotour Pro in the Settings window of Panotour Pro .
4. When does the crash occur ?
Directly when starting PTP? when adding a scene? when selecting a scene ? When building a tour ? etc...
buscar71
by buscar71 » Wed Aug 08, 2018 3:36 pm
thanks for your reply.
1. I tried each version, but only 64 bits works.
2. I have up to date drivers.
3. I changed memory setting but it changed nothing.
4. Problem occure just after adding photos.
I tried to install older version and it works fine. The problem is only with new version of software.
Likes: 14 posts
by bdd » Wed Aug 08, 2018 3:53 pm
By "older version", which one do you mean ?
buscar71
by buscar71 » Wed Aug 08, 2018 3:55 pm
2.5.9 64 bits
Likes: 14 posts
by bdd » Wed Aug 08, 2018 4:06 pm
Did you try 2.5.10, 2.5.11 or 2.5.12 versions ?
They are available here : http://download.kolor.com/ptp/stable/history
If the crash occurs after the add of a scene, it may be during the render of the scene, so it may be linked to the graphical card.
Did you try to install last version of the graphical card driver ?
buscar71
by buscar71 » Wed Aug 08, 2018 4:20 pm
I have the latest drivers. I also tried ver. 2.5.12 but it also crashed. Are you able to check my reports?
Likes: 14 posts
by bdd » Thu Aug 09, 2018 9:03 am
Which e-mail did you use in the report form ?
I don't find the one you are using on the forum.
buscar71
by buscar71 » Thu Aug 09, 2018 9:39 am
I sent you my email in PM
Likes: 14 posts
by bdd » Thu Aug 09, 2018 10:03 am
The crashs occured in the card driver dlls : ig4icd32 and ig4icd64 , not in the Panotour binary or dlls .
By the way, It's strange that you got drivers in 32bits AND in 64bits at the same time
I suggest you to download latest drivers there :
https://downloadcenter.intel.com/produc ... cs-Drivers
buscar71
by buscar71 » Fri Aug 10, 2018 10:47 am
Unfortunately I have the latest drivers. Is it possible that I have too old computer? Can you support older laptops?
