PanoramaCombobox "marker" showing up as question mark
bitbyter
Liked in: 3 posts
by bitbyter » Thu Jul 19, 2018 11:37 pm
Hi, I just used the newest panoramaCombobox and the "marker" character which is used to indicate the current selection shows as a question mark. By default, it's supposed to be a black triangle pointing down (to indicate the dropdown, and it gets rotated 90 degrees to show the currently selected pan or group. Mine is just showing as a ? which gets rotated.
Anyone know whats going on? Thx, Scott
Likes: 14 posts
Re: PanoramaCombobox "marker" showing up as question mark
by bdd » Tue Jul 24, 2018 10:27 am
Did you change the font used inside the combobox ?
If the character is not found in the font used by the combobox, it is replaced by the "default" charater of the font.
This default character depends on the font.
It may be a question mark, a square, or whatever .
