Black screen between pano changes on iphone 5 - no pano fade
bob1010
Liked in: 3 posts
by bob1010 » Thu Jul 19, 2018 1:01 pm
Hi, I've just updated to panotour pro V2.5.12 and when I view the following tour on my iphone 5 there is a black screen when you change scene in Safari browser, rather than the nice subtle fade between panos:
https://www.irisimage.com/360-degree-ga ... -with-ext/
in the past versions the transition between panos would have look like this:
https://www.irisimage.com/360-degree-ga ... build.html
Will this bug be fixed in the next update?
Regards,
Rob
bob1010
Liked in: 3 posts
Re: Black screen between pano changes on iphone 5 - no pano
by bob1010 » Thu Jul 19, 2018 7:52 pm
I've read the full update details for 2.5.12 and now understand the issue:
"Until the release of a fix for iOS and/or krpano, the default transition for iOS devices will be made with no blend.
The Effects > Loading transition Panotour plugin will also not be applied in virtual tours on iOS devices. · Decoding issue with Panorama Combobox and Simple Thumbnails Bar plugins into Panotour Standard Edition
Due to a krpano script decoding issue, the Panorama Combobox and Simple Thumbnails Bar plugins have been corrupted. They are now repaired."
I've reverted back to 2.5.11 as the combo box and simple thumbnail bar both seem to work ok on my virtual tours & the transition effect is working on my iphone 5 in safari - hope you're able to sort the issue in a later update.
This test is made in 2.5.11 and the transition between panos is fine.
https://www.irisimage.com/360-degree-ga ... &b-revised
by benji33 » Mon Jul 30, 2018 3:09 pm
You can try the 2.5.13 released last week if your tour doesn't contain any video scene.
bob1010
Liked in: 3 posts
by bob1010 » Thu Aug 09, 2018 8:31 pm
Thanks Ben, I will try that.
