Registration failed   [SOLVED] - View the solution
PieroA
Likes: 4 posts
Registration failed
by PieroA » Mon Jul 16, 2018 2:22 pm
Just bought a new PT 2.5 licence, applied along with my registering email, software display ..." registered to <my mail>" but it still run in demo mode.
I am trying to edit a tour that has been initiated in demo mode bit I think it shouldn't make any difference.
Btw, is the forum the only official product support?
Thank you
Piero
PieroA
Likes: 4 posts
Re: Registration failed  [SOLVED]
by PieroA » Mon Jul 16, 2018 2:26 pm
SOLVED !
I had to save to project with another filename, re-open it, elaborate and publish and all went fine.
Just spend some time
