Error Message   [SOLVED] - View the solution
afibeto
Error Message
by afibeto » Thu Jul 05, 2018 9:12 am
Good morning.
Already created a tour 360º, you can check it out here https://www.todoboda.com/bodas/banquete ... our360#_=_
Got the following problem: all the tour is well done, but when i clic in the right top section "suite" > "salon suite", some bugs appears.
I´´m adding you a screenshoot ... please have a look on this.
Thanks!!
Re: Error Message
by Destiny » Thu Jul 05, 2018 9:16 am
You have images missed in the up-loading.. Either your server is full or it stopped uploading.
Re: Error Message
by benji33 » Wed Aug 01, 2018 3:09 pm
As all others scenes are working it seems to be a scene upload issue.
Try to upload again the 6814_hotelsevillacenterdata/salon_suite_95 directory.
virtualdiorama
Likes: 3 posts
Re: Error Message
by virtualdiorama » Mon Aug 06, 2018 1:37 pm
Hi guys,
I have a similar issue, its started this summer.
Here is a link to a tour a built last Friday: http://83-136-250-41.uk-lon1.host.upclo ... osaic.html
I opened the project today and if you look at the video you see my problem, If I rebuild the project everything works. But I cant rebuild the project each time I need yo open it.
Hopefully you have the answer.
Best regards
j.
error.mov
(17.46 MiB) Downloaded 455 times
Johannes Söderström
johannes.soderstrom@virtualdiorama.com
virtualdiorama.com
Likes: 14 posts
Re: Error Message
by bdd » Tue Aug 07, 2018 10:14 am
virtualdiorama wrote:Hi guys,
Best regards
j.
What do you mean by "I opened the project today" ?
Do you mean the tour you built last friday ?
Or the kpt project in Panotour ?
If it is the project in Panotour, then did you built it before having the errors seen in the video ?
I ask these questions just to understand what you meant by "I cant rebuild the proecjt each time I need to open it" .
If the errors are displayed after a build that did not re-generated the tiles, can you send us the generated XML files ?
virtualdiorama
Likes: 3 posts
Re: Error Message
by virtualdiorama » Tue Aug 07, 2018 10:25 am
I reopen the project in panotour that I builded on the Friday before. When I checked it at the krpano testing server thats the result I got (the video)
I checked the error log and files that supposed to be missing didnt exist on my server and there it works so I dont understand. See the attached files.
Johannes Söderström
virtualdiorama.com
Likes: 14 posts
Re: Error Message
by bdd » Tue Aug 07, 2018 10:35 am
Looking at your server files, it seems that the build, or the upload, took more than 25 minutes!
for a tour with only eight scenes.
It's quite long.
Did you try to run the tour, while the build/upload was still running ?
virtualdiorama
Likes: 3 posts
Re: Error Message
by virtualdiorama » Tue Aug 07, 2018 10:37 am
No, but the panoramas are big 26624x13312 px
Johannes Söderström
virtualdiorama.com
virtualdiorama
Likes: 3 posts
Re: Error Message
by virtualdiorama » Tue Aug 07, 2018 1:44 pm
I have "do not generate tiles on build" activated but it still builds the hole thing from scratch each time I press the build tour button. Picture attached.
Johannes Söderström
virtualdiorama.com
virtualdiorama
Likes: 3 posts
Re: Error Message  [SOLVED]
by virtualdiorama » Sat Aug 11, 2018 11:23 am
I found the problem, the issue is the .cache file. The same problem has occurred each time when I have created a project from presets. So when I removed the .cache file a from the project and rebuild it, the issues are gone.
Thanks for your help!
j.
Johannes Söderström
virtualdiorama.com
