Nadir Patch Option Has Disappeared in 2.5.12?   [SOLVED] - View the solution
NachoNick
Liked in: 5 posts
by NachoNick » Thu Jul 05, 2018 2:47 am
I have just updated to PTP 2.5.12 version this morning, went to go and build a new tour, and I have found that the Nadir Patch option has disappeared from the menu when you have a pano selected! (See attached screen shot)
Is this a bug? If not, how do I select an image file now to patch the nadir of a pano?
Thanks,
Nick.
Re: Nadir Patch Option Has Disappeared in 2.5.12?
by Destiny » Thu Jul 05, 2018 3:08 am
Strange.... I take it that your pano is 2:1..Not sure if that would make a difference...
I checked my MAC version and its there...
Anyway.. There is a much better option to add a logo/patch to the nadir by using the Logo Plugin.. You can set that to the Nadir and even add a URL... You can also set it to spin with the pano as if its attached to the image or allow it to free spin.. Its a heaps better option..
NachoNick
Liked in: 5 posts
by NachoNick » Thu Jul 05, 2018 5:12 am
Hi Destiny,
Yes it is strange that its disappeared. I didn't know the logo plugin could do all of that. I'll have to check it out as the features sound great!
Thanks,
Nick.
NachoNick
Liked in: 5 posts
by NachoNick » Thu Jul 05, 2018 5:35 am
Well this is strange...the nadir patch option has just appeared again for me out of no where! Very weird.
by Destiny » Thu Jul 05, 2018 6:51 am
This is really the best option. You can also add a different Logo to any Pano, using the Specific Logo Plugin...
Likes: 14 posts
by bdd » Thu Jul 05, 2018 8:48 am
NachoNick wrote:I have just updated to PTP 2.5.12 version this morning, went to go and build a new tour, and I have found that the Nadir Patch option has disappeared from the menu when you have a pano selected! (See attached screen shot)
Thanks,
Nick.
What is the FOV of your scene ?
In your screenshot we cannot see the "Projection" properties.
If your scene is not a 360x180 one, then the Nadir patch option is not available .
NachoNick
Liked in: 5 posts
Re: Nadir Patch Option Has Disappeared in 2.5.12?  [SOLVED]
by NachoNick » Sat Jul 07, 2018 1:06 am
Yes it is a full spherical pano. Don't worry it seems the option has reappeared out of no where.
Thanks!
