Connection timeout while making map API call. Try to reload
Strider
by Strider » Fri Jun 22, 2018 12:44 am
On various target platforms, I keep getting the following error on different walkthroughs:
Connection timeout while making map API call. Try to reload the page.
What can be done to fix this? I'm trying to get clients and the error messages really make me look bad =(
To reproduce this, I merely need to look around in various directions on any walkthrough that I produce. It doesn't matter if the tour is hosted on a web server or executed locally.
Likes: 14 posts
Re: Connection timeout while making map API call. Try to rel
by bdd » Fri Jun 22, 2018 8:32 am
Which map provider are you using ?
GoogleMaps, BingMaps, OpenStreetMap, Yandex ?
If you use GoogleMaps or BingMaps, did you enter a key to access their API ?
Strider
by Strider » Fri Jun 22, 2018 6:59 pm
Yes I did... but it was 5 years ago. I wish I could recompile it but I don't have the Panotour work file any more because of a SDD failure :-(
