A log message
Inmobiliaria30
A log message
by Inmobiliaria30 » Tue Jun 05, 2018 6:04 pm
When I put the tour in my well, its appear a message with an error
ERROR: ve137data/graphics/scrollarea.js - loading failed! (decoding error)
Can anyone help me?
Thanks!
Likes: 14 posts
Liked in: 129 posts
Re: A log message
by bdd » Wed Jun 06, 2018 10:44 am
You are working with Panotour (standard version) not Panotour Pro, I guess ?
This decoding issue will be fixed in nex release of Panotour .
It appears with plugins like the Thumbnails Bar or the Panorama List .
While waiting for newt release of Panotour, you can either remove those plugins from your tour, and use a Panorama Menu for example, or use the older version of Panotour.
You can download it here :
http://download.kolor.com/pt/stable/history
Inmobiliaria30
Re: A log message
by Inmobiliaria30 » Wed Sep 12, 2018 10:25 am
Hi again!
I.ve been using the older version of Panotour you posted, but I still have the same problem. How can I remove those plugins?
When I open de html file, there is a problem with the browser security restrictions,I can´t see it!
I think is something about the bugs, is it possible?
Regards.
Re: A log message
by benji33 » Fri Sep 14, 2018 8:14 am
The latest 2.5.14 version is required to correct this issue. Is it your version ?
The browser cache is cleaned too ?
