Panotour videos now not broken on EVERY IOS 11+ device?
VanLad
Likes: 3 posts
Re: Panotour videos broken on EVERY IOS 11+ device in the wo
by VanLad » Thu Jun 14, 2018 12:47 pm
3DStudio wrote:I have one tour that seems to be working, but I don't know what version I used when publishing it.
Are you able to see the panotour version in some files?
Maybe an older version than 2.5.1 would work better?
Old versions can be found here:
http://www.kolor.com/download-previous-versions/
Thanks for the link. Is it possible to post a link, I will play on an ipad to test?
VanLad
Likes: 3 posts
by VanLad » Thu Jun 14, 2018 5:54 pm
Clément_S wrote:Hi Steve, VanLad,
I just talked with the developers and they told me that they are working hard on solving this bug. Unfortunately, there's no workaround right now.
We will post here as soon as a solution is available.
Thank you in advance for your patience and sorry for the inconvenience caused.
Best,
Clément - Kolor team
Update for anyone who is interested, I have just downloaded IOS 11.4.1 beta on an Ipad. No luck exactly the same, black screen on 4th click/selection of video. Anybody have access to IOS 12 beta?
3DStudio
by 3DStudio » Thu Jun 14, 2018 6:46 pm
What OS are you using when building the tours? I’ve been using mac. Same problem on Windows?
VanLad
Likes: 3 posts
by VanLad » Thu Jun 14, 2018 6:52 pm
3DStudio wrote:What OS are you using when building the tours? I’ve been using mac. Same problem on Windows?
Win 10.
Its an Apple IOS thing for me, working fine on windows desktops as far as I know. Did you say you had a working tour, can you post a link? If it works then it may help the developers.
3DStudio
by 3DStudio » Thu Jun 14, 2018 7:03 pm
I was checking the URL on my iPhone, it went black on 4th spot. I can check on the iMac and iPad tomorrow because I think it worked somewhere.
URL: https://vrtour.elisaiot.com/ABB/CH/
3DStudio
by 3DStudio » Fri Jun 15, 2018 6:54 am
Just installed iOS 12 Beta on my iPhone, unfortunately same problem.
https://vrtour.elisaiot.com/ABB/CH/ works on my iMac but not on any other iOS device (iOS 11 and newer).
VanLad
Likes: 3 posts
by VanLad » Fri Jun 15, 2018 9:51 am
3DStudio wrote:Just installed iOS 12 Beta on my iPhone, unfortunately same problem.
Thanks very much, very cool tour. This makes this much more serious as Apple are not going to address this issue any time soon.
VanLad
Likes: 3 posts
by VanLad » Fri Jun 15, 2018 10:05 am
Best,
Hi Kolor,
The tours have been tested on IOS 12 and the same thing happens, black screen on 4th click on pano video.
You need to say clearly on your website now that if a potential buyer of the software wants to use video and a mobile Apple device THIS SOFTWARE DOES NOT WORK.
Can you please give an update, anything, a clue, just a response, anything!
by benji33 » Tue Jun 19, 2018 3:36 pm
The issue have been identified today.
Let us investigate more to be able to offer the better solution for iOS 11+ devices.
Thanks for your patience.
VanLad
Likes: 3 posts
by VanLad » Tue Jun 19, 2018 3:46 pm
benji33 wrote:The issue have been identified today.
Excellent news, thanks, look forwards to a possible solution.
by benji33 » Thu Jun 21, 2018 3:08 pm
Try this new 2.5.12 release of Panotour Pro for the iOS11 and Safari issue.
http://www.kolor.com/2018/06/21/virtual ... or-update/
manderson
Likes: 4 posts
by manderson » Thu Jun 21, 2018 3:39 pm
Great News Everyone! There is an update to Panotour and it addresses this bug!!!! I haven't tried it yet, but I am super excited to test it tonight! Great work everyone! Thank you Kolor!
VanLad
Likes: 3 posts
by VanLad » Fri Jun 22, 2018 11:01 am
benji33 wrote:Try this new 2.5.12 release of Panotour Pro for the iOS11 and Safari issue.
That's great, thanks. I have tried the new version and seems to be working, strange problem with thumbnails disappearing but deleting Panotour temp files had solved the problem. I think?
Going forwards this is great, but is there an easier fix for previous tours other than re-making every single tour? I tend to encrypt xml's so that would not be an option for me?
Any thoughts?
Re: Panotour videos now not broken on EVERY IOS 11+ device?
by benji33 » Wed Jun 27, 2018 3:52 pm
For encrypted tour you have to rebuild the tour.
For non encrypted a patch can be applied into the CORE.xml files
VanLad
Likes: 3 posts
by VanLad » Wed Jun 27, 2018 4:04 pm
benji33 wrote:For encrypted tour you have to rebuild the tour.
Thanks, at least it is working going forwards
3DStudio
by 3DStudio » Thu Jun 28, 2018 5:45 am
What path should I add to the core.xml file?
3DStudio
by 3DStudio » Thu Jun 28, 2018 9:32 am
The bug still exist for VR!
manderson
Likes: 4 posts
by manderson » Thu Jun 28, 2018 3:04 pm
What do you mean by VR? Stereo video? 360/180 video or rendered 3D animations with a game engine? What error are you getting? And what is your workflow?
Previous
