issue with floorplan on smartphones
ichikawa-hiroshi
Liked in: 6 posts
by ichikawa-hiroshi » Fri May 04, 2018 8:15 am
I have an issue with floorplan on smartphones.
that is, after the floorplan gets displayed on iPhone, pinching out( trying to make the floorplan zoom in), a pano gets out of shape and,,,
to see my point, please refer to this tour on your smartphones( after the tour starts, click on a character that you can see in the lower right. then try to make a floorplan zoom in, using two fingers):
http://cogration.heteml.jp/index-dg-mobile05.html
what should I do to fix the issue?
Any feedback is greatly appreciated.
thank you in advance
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: issue with floorplan on smartphones
by signmaster » Mon May 07, 2018 4:14 am
Check out this post.http://www.kolor.com/forum/viewtopic.php?f=38&t=38422
Perhaps this may be a solution. I used it on this job. http://360gallerytours.com.au/swanhill/
Steve
ichikawa-hiroshi likes this post.
ichikawa-hiroshi
Liked in: 6 posts
by ichikawa-hiroshi » Mon May 07, 2018 4:26 am
Thank you for the link.
looks like this is a frequently asked question. but, I just wondered why things have not been solved yet.
by benji33 » Wed Aug 01, 2018 3:14 pm
Because the only way to solve it is to block the pinch. And pinch is used a lot. So what is the better choice ;) ?
