Virtual Tour blank   [SOLVED] - View the solution
Caleb111117
Virtual Tour blank
by Caleb111117 » Mon Apr 16, 2018 3:55 pm
Does anyone have any idea why this virtual tour is blank?
https://www.stjohnscentre.org/room-hire/rooms-hire/
It works fine on my website but not on my clients.
http://blushandposephotography.co.uk/test-2/
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Virtual Tour blank  [SOLVED]
by 360-compunics-com-ni » Tue Apr 17, 2018 12:57 am
The iframe calls the tour via "http", while the site is served via "https".
Change it to "https" and it should work.
Caleb111117
by Caleb111117 » Tue Apr 17, 2018 9:56 am
Great! That worked. Thanks
Users browsing this forum: Google [Bot] and 2 guests
