Panotour et BDD SQl   [SOLVED] - View the solution
eddy66
Panotour et BDD SQl
by eddy66 » Fri Mar 02, 2018 6:28 pm
Merci de m'accueillir sur votre forum.
Je souhaiterais savoir s'il est possible de lier des élément Panotour (hotspots) à une base de données du style PostgreSQL par ex ? :rolleyes:
Merci beaucoup pour vos réponses et éclairages à ce sujet.
Cordialement
eddy
Thank you for welcoming me to your forum.
I would like to know if it is possible to link Panotour elements (hotspots) to a PostgreSQL style database for example? : Rolleyes:
Thank you very much for your answers and insights on this subject.
cordially
eddy
Re: Panotour et BDD SQl
by benji33 » Tue Mar 06, 2018 10:01 am
This is not possible.
eddy66
by eddy66 » Tue Mar 06, 2018 10:54 am
Dommage
Merci pour votre réponse
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Fri Mar 09, 2018 12:07 pm
While it is not possible using only PTP's GUI features, data storage and retrieval from external sources can be integrated thanks to its plugin system and the generated XML output being open for customization and extension.
Following is a link to a short clip demonstrating a Heatmap creation and presentation solution recently implemented, data storage and retrieval in this case is done using a MySQL database.
In data collection mode the users' views are stored as hits per location, and in presentation mode the different hitranges get displayed using colored hotspots that are automatically created, there is no external visualization toolkit involved. Several filters can be applied through modified versions of the new combobox plugin.
https://vimeo.com/259309243
2 people like this post.
eddy66
Re: Panotour et BDD SQl  [SOLVED]
by eddy66 » Fri Mar 09, 2018 1:31 pm
Thank you very much !
I go to learning it
