Limit panning speed,modifying speed panning when using arrow   [SOLVED] - View the solution
adam140185
by adam140185 » Mon Feb 19, 2018 9:51 pm
is it possible to modify the speed of panning/tilting/zooming when i browse with arrows keys on keyboard ?
(overwrite the default speed)
(when you keep key pressed, that's way too fast...)
or
Is it possible to limit the panning speed, regardless of mouse sensitivity? Some people have commented that they spin too fast and get dizzy?
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Limit panning speed,modifying speed panning when using a  [SOLVED]
by 360-compunics-com-ni » Mon Feb 19, 2018 11:19 pm
The following post has a link to the relevant KRPano-documentation as well as the method to incorporate such settings into your tour, just look for the "keyb*"-related settings: https://www.kolor.com/forum/viewtopic.php?f=91&t=35886&p=198241&hilit=Panning#p198169
adam140185
by adam140185 » Wed Feb 21, 2018 10:25 am
Thank you for the info.
