Starting tour with a flat image affects all the other images
property3d
by property3d » Thu Feb 08, 2018 2:18 am
Hi guys,
I'm building a tour starting from a floor plan of a building, but when I set this flat image's output projection as flat image, I land on extremely zoomed in 360 images and I can't zoom out of it.
I tried changing output projection as spherical, then it works but the floor plan looks stretched now.
Can someone please have a look into this issue?
Thank you.
Alex
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: Starting tour with a flat image affects all the other im
by signmaster » Thu Feb 08, 2018 5:51 am
Hi Alex.
This might be of some help, it's a screen grab of my settings of a tour starting with a flat pano. You may be able to get some settings off it.
Steve
property3d likes this post.
by Annis » Thu Feb 08, 2018 1:21 pm
Could you show me your settings? Is the tour online? What plugins are you using in your tour? Anything that uses KEEPVIEW?
property3d
by property3d » Thu Feb 08, 2018 10:02 pm
Thank you @signmaster , I tried your settings but no luck :( Thank you for your help though!
@annis I left it as default, attached is the screenshot of the settings.
I'm not sure if im using any keepview related plugins, but here's the list of plugins that im using for this tour
Circles Control Bar, Floor Plan, Simple Button - for floor plan, Gyroscope, Force Landscape on Mobile, Logo, Panorama Menu and GArrows.
I haven't put it up online yet :) but let me know if it helps for you to check.
Thank you!
Paw
by Paw » Sun Mar 18, 2018 11:16 am
Hi Alex:
maybe you found a solution by now??
I had to set Max/Min zoom level (both) to 110% to get it to work - see screenshot.
Live link at: http://swfl360.com/jm2916/JM2916.html
If you found a better solution - please let me know.
Thanks,
Susanne
