Req: Function to disable plugins for mobile devices   [SOLVED] - View the solution
ThomasK
by ThomasK » Thu Jan 18, 2018 9:15 am
End users are switching more and more to mobile devices, so Kolor should consider this trend in Panotour Pro.
A function to disable plugins should be included in Panotour to unclutter the smaller screen on mobile devices.
Or am I asking too much? ;-)
Re: Req: Function to disable plugins for mobile devices  [SOLVED]
by Annis » Thu Jan 18, 2018 10:16 am
Well, as you know PTP development has been slowed... There are many features that are direly needed but not implemented yet unfortunately.
Anyway, have you seen Michael Brüning's plugin Device Check? It should be exactly what you need.
http://www.kolor.com/wiki-en/action/vie ... .C3.BCning
ThomasK
by ThomasK » Thu Jan 18, 2018 10:28 am
Thanks Annis for the hint to Michael's plugin.
So GoPro is short on money after the drone disaster? Perhaps they want us to switch to the upcoming Pano2VR 6 ?
Don't get worry, just kidding! =D
Annis likes this post.
