very low resolution in webcontent spot
bonapictura
Liked in: 4 posts
by bonapictura » Mon Jan 08, 2018 3:38 pm
I'm working on a tour where I want to use webcontent spots to display youtube videos or websites (i.e. on a television screen in the scene).
When I use that the resolution of the webcontent is very low. I found a way to correct it by editing the xml file but I think it should be better by default. Maybe it's a bug since the last panotour pro update? (I'm on version 2.5.9)
Am I missing something or is this a bug?
To illutrate the problem:
Creating a webcontent spot pointing to a website
Result: resolution too low
Editing index.xml
Perfect after edit:
Re: very low resolution in webcontent spot
by Annis » Tue Jan 09, 2018 2:33 pm
Well it's not a bug, it's set to the size of the spot, and as you said if you want a different size you can edit the xml.
Ideally in the spot style you should be able to set your own default size for the content of the website box, which would constitute a feature request.
