Hide hotspots by keyword problem
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Sun Dec 03, 2017 1:28 am
Hi guys,
I'm having a problem with hiding a hotspot by keyword.
When using this it only hides the hotspot on the same pano... not on the complete tour.
Is there anyway we can hide hotspots on all pano's (action triggered with another hotspot)
Regards,
Xander
Re: Hide hotspots by keyword problem
by Annis » Tue Dec 05, 2017 10:33 am
This topic was marked as solved, did you find your solution?
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Wed Dec 06, 2017 12:41 am
No, think I still have this bug..
by Annis » Wed Dec 06, 2017 9:42 am
Your action only affects the current scene, so when moving to a new one the chosen hotspots aren't hidden. You'd need to find a way to add a check at each scene start, if you'd hidden this type of hotspot then it stays hidden 'til you reactivate them.
This would require custom development though, I would recommend contacting Michael Brüning (360-compunics-com-ni - http://dev.compunics.com.ni/) who should have the skills to help you with this.
Xander Berkenhagen likes this post.
