ZOOM IN ACTION do not work!!
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Thu Nov 23, 2017 6:36 pm
Hi everybody,
I create a poligonal hotspot an I set a zoom action to it. I want that when I click on this spot it zoom to a specific FOV!! (because on this fov there are coming out others hotspots, and I want to make those visible) There are two options: 1) One step (it works but the zoom is not enough) 2)Destination Fov
When it is seted to destination fov it do not work. How can I let it work??
Is there a way to set the tooltip of polygonal hotspot always visible??
thanks
Ugo :)
Re: ZOOM IN ACTION do not work!!
by Annis » Fri Nov 24, 2017 11:25 am
What is the max zoom of your scene? If you're trying to zoom in further than the max zoom the action will not work.
Have you thought of using the Go to panorama action with the move to custom view transition instead? http://www.kolor.com/wiki-en/action/vie ... ustom_View
You will still be restricted by your scene's zoom limits.
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Fri Nov 24, 2017 11:49 am
I tried to use this transition but I can not see the VIEW!!!
best
Ugo
by Annis » Fri Nov 24, 2017 12:29 pm
Ah. Is this a planar or spherical scene?
Try unchecking "Limiti risoluzione immagine" ?
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Fri Nov 24, 2017 2:27 pm
this is a planar image...Gigapixel!!
No way also with "limit the size resolution" unchecked!
Maybe is there a way to create a custom transition for example modifying the zoom in transition to a wanted fov??
by Annis » Fri Nov 24, 2017 3:34 pm
Hm yes it should be possible to create such a transition. That would probably be the way to do what you're looking to do.
The zoom in action won't work because you're on a planar image, so the fov for the planar image is between 1° and 0.x, so you're trying to go to 29° which isn't compatible with a planar image. So this would be why the action isn't working for you.
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Fri Nov 24, 2017 3:51 pm
Ok I understand...mhh and how can I create this "special" transition ??
by Annis » Fri Nov 24, 2017 5:27 pm
Copy one of the existing ones from the templates folder to the user directory and modify the parameters. You'll need to know krpano to know what to do though, it's beyond my skills unfortunately.
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Fri Nov 24, 2017 5:46 pm
Ok thanks...maybe you know somebody that have this skills??
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Fri Nov 24, 2017 10:55 pm
You can zoom in/out of a planar pano as well, only the PTP GUI does not allow to input values smaller than "1".
So using the "Call Custom Code"-action you can assign this function to your polygon hotspot:
looktohotspot(get(name), 0.35, tween(linear,2.0) );
"0.35" is the FOV in this example, and "2.0" is the time for the "lookto/zoom"-action, adjust those values as needed.
Annis likes this post.
