How can I change the hotspot layer?
fifilee0610
by fifilee0610 » Tue Nov 07, 2017 2:44 am
I can not make the iframe is behind spotpolygon3468. I need someone help to resolve.
one part of my code is as follows...
<hotspot name="spotpolygon3468"
           tag="polygon"
           style="PolygonDefaultPolygonSpotStyle"
           descriptionid=""
           handcursor="false"
           renderer="css3d"
    <point ath="125.271000" atv="-18.378900" />
    <point ath="175.076280" atv="-18.000000" />
    <point ath="174.697560" atv="18.568440" />
    <point ath="125.081640" atv="18.757980" />
  </hotspot>
  <hotspot name="spotpolygon3468" renderer="css3d" devices="flash" zorder="1"/>
  <hotspot name="spotpolygon3468" renderer="css3d" devices="html5" zorder="3" zorder2="1"/>
  <action name="hidepanopolygonalspots">
    set(hotspot[spotpolygon3463].visible, false);
    set(hotspot[spotpolygon3464].visible, false);
    set(hotspot[spotpolygon3465].visible, false);
    set(hotspot[spotpolygon3466].visible, false);
    set(hotspot[spotpolygon3467].visible, false);
    set(hotspot[spotpolygon3468].visible, false);
  </action>
  <action name="showpanopolygonalspots">
    set(hotspot[spotpolygon3463].visible, true);
    set(hotspot[spotpolygon3464].visible, true);
    set(hotspot[spotpolygon3465].visible, true);
    set(hotspot[spotpolygon3466].visible, true);
    set(hotspot[spotpolygon3467].visible, true);
    set(hotspot[spotpolygon3468].visible, true);
  </action>
  <action name="removepanopolygonalspots">
    removehotspot(spotpolygon3463);
    removehotspot(spotpolygon3464);
    removehotspot(spotpolygon3465);
    removehotspot(spotpolygon3466);
    removehotspot(spotpolygon3467);
    removehotspot(spotpolygon3468);
  </action>
  <hotspot name="spotwebcontent3582"
           devices="html5"
           renderer="css3d"
           tag="webcontent"
           visible="true"
           distorted="true"
           url="%FIRSTXML%/graphics/spotsback.png"
           ath="-122.264155"
           atv="-1.568506"
           width="1548"
           height="967"
           rx="-0.54226515690913657"
           ry="2.8488781683557152"
           rz="0.88484672589593771"
           enabled="false"
           capture="false"
           handcursor="false"
           zorder="0"
           zorder_backup="0"
           onloaded="add_iframe(./canvas/, get(width), get(height));"
Re: How can I change the hotspot layer?
by Annis » Mon Nov 13, 2017 10:37 am
What are you trying to do? I do not understand.
Keep in mind that we do not offer KrPano support and my own knowledge is very limited so I might not be able to help you with this point.
fifilee0610
by fifilee0610 » Tue Nov 14, 2017 3:03 am
The hotspot "spotwebcontent3582" that is a iframe in my code. I try to let it behind spotpolygon3468 but I can not achieve.
Does "iframe" must always be the top?
Likes: 14 posts
Liked in: 129 posts
by bdd » Tue Nov 14, 2017 1:50 pm
You can try to set a higher zorder to spotpolygon3468 than the one set on spotwebcontent3582.
But I think that, even with a higher zorder, the iframe will be above the polygon spots.
Because even if the layer used to position the frame is lower, the iframe may be displayed on top.
fifilee0610
by fifilee0610 » Wed Nov 15, 2017 2:53 am
Thanks, bdd.
The same is true of my current code. I have tried to set higher zorder but it didn't be achived.
