Help with HOTSPOT!!   [SOLVED] - View the solution
Ugo Visciani
Liked in: 3 posts
Help with HOTSPOT!!
by Ugo Visciani » Mon Nov 06, 2017 6:38 pm
Hello folks.
I need your help...I want to have this kind of HOTSPOT (http://www.burger.si/WWI/360/index.html) in my vr tours. Is that an extra plugin?? It is especially possible with PTP??
thanks
Ugo
this kind of plugins :)
Ivan Majc likes this post.
Re: Help with HOTSPOT!!  [SOLVED]
by Annis » Mon Nov 13, 2017 11:13 am
They're just hotspots with a custom image. One style per spot to use a different image.
For example here: http://www.kolor.com/virtual-tours-file ... alpespace/ (made with PTP)
Here is one of the spots: http://www.kolor.com/virtual-tours-file ... point3.png
Edit (12/2017) - Instead of creating one spot and graphic per location, have a look into using the COol Hotspots plugin - http://www.kolor.com/wiki-en/action/vie ... ccon_Gibod
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Mon Nov 13, 2017 1:24 pm
Ok thanks Annis!! Another question...is there a way to group the plugs-in/hotspot styles in PTP?? If I have to use this method to create this specific hotspots, the workarea and hotspot style will become very confuse, because I have to integrate a lot of Hotspot!!
thanks
Ugo
by Annis » Mon Nov 13, 2017 1:27 pm
Unfortunately not, though it'd be a great UI improvement. Then again there are so many things that would be great UI improvements...
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Mon Nov 13, 2017 1:33 pm
Ok thanks....maybe in the next PTP versions...this feature would improve and speed up a lot the workflow of the software ;)
best Ugo
