Deactivate Panotour Pro   [SOLVED] - View the solution
zil-imu
by zil-imu » Thu Oct 19, 2017 3:04 am
I would like to install Panotour Pro to my new PC. Do I need to deactivate the serial key on my old PC first or I can just uninstall the software and install it on my new PC? Kindly assist.
Re: Deactivate Panotour Pro  [SOLVED]
by Annis » Fri Oct 20, 2017 10:27 am
Just uninstall it then reinstall on the new computer. :)
On Mac removing the licenses is more difficult but you're on Windows.
zil-imu
by zil-imu » Fri Oct 20, 2017 10:55 am
Yes I'm using Windows. Thank you so much :)
Annis likes this post.
