Video 360 on Tour (FAIL)   [SOLVED] - View the solution
jonatasgarcia
by jonatasgarcia » Wed Oct 04, 2017 2:17 pm
Hello. I want to do a virtual tour with videos in 360º but is giving this error when generating the .html
Can anyone help me why is this happening?
Nacho
Re: Video 360 on Tour (FAIL)
by Nacho » Sun Oct 15, 2017 9:27 am
I had similar probem and I have solved it including the propoer meta data inside the fideo file. In my case, using video generated with a Ricoh Theta, It has been done playing the video with the Rocoh Theta player. In the momento to frag and drop the video on the application, it take several seconds to include those meta data creatig a new video file. When I include this new new video file in Panotour, the virtual visit works properly.
Re: Video 360 on Tour (FAIL)  [SOLVED]
by Annis » Mon Oct 16, 2017 10:19 am
Try replacing your video file in the built tour and don't forget to add alternative files in low and high res to maximise compatibility.
http://www.kolor.com/wiki-en/action/vie ... il_the_end
http://www.kolor.com/wiki-en/action/vie ... e_Versions
jonatasgarcia
by jonatasgarcia » Fri Oct 20, 2017 9:22 pm
Thank you Annis!!
I got including the .ogv and .webm files on the tour!!
Annis likes this post.
