update tool affect on older tours
macalenny
by macalenny » Mon Sep 25, 2017 2:38 am
I used the krpano update tool to update the .js and .swf files of an older tour.
all works except I have hot spots that pen gallery images, these stopped working.
I reverted back to old files and works.
is there a way to avoid this and still update to latest?
Re: update tool affect on older tours
by Annis » Mon Sep 25, 2017 10:26 am
Which PTP version tours are you using the update tools on?
macalenny
by macalenny » Mon Sep 25, 2017 12:02 pm
krpano 1.19-pr10 (build 2017-05-10)
updated to latest, just release version from 9/21, I believe.
by Annis » Tue Sep 26, 2017 10:07 am
You'd have to remove all the HTML5 plugins of your tour, and even then the upgrade is not guaranteed to work because of the xml changes.
macalenny
by macalenny » Tue Sep 26, 2017 11:36 am
OK thank you.
So a better practice would be to save ptp project an render again new, right?
by Annis » Tue Sep 26, 2017 2:20 pm
Save it as a separate project and remove the plugins, render in a new spot and try updating it.
As I said, it is not guaranteed to work, you are essentially taking an English dictionary and changing the language so things won't necessarily be understandable to work!
