Custom view keeps resetting   [SOLVED] - View the solution
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Thu Sep 21, 2017 4:00 pm
When I add a action with a custom view to my tour and click on generate Panotour resets the custom view back to pano view.
When it is rendered it does not use the custom view I set it on. Is there a way to fix this?
It also happens when I have no plugins added to the tour.
I;ve added a screen recording
Kind regards
custom view.mov
(19.65 MiB) Downloaded 42 times
Re: Custom view keeps resetting
by Annis » Thu Sep 21, 2017 4:18 pm
There is no way to fix it, it is a critical bug in the latest version of PTP.
We are already aware of it (see the bug report topic i've stickied on this subject) - viewtopic.php?f=92&t=36289
If the issue is penalising for you, you should revert back to 2.5.7 until an update is available.
