Custom Hot Spot
coccoce
Custom Hot Spot
by coccoce » Thu Aug 31, 2017 9:51 pm
Dear I have created a custom hotspot as per your instructions: http://www.kolor.com/wiki-en/action/vie ... m_hotspots
However I do not see it in the hotspot menu.
Can you help?
Cesar
Re: Custom Hot Spot
by Destiny » Thu Aug 31, 2017 11:17 pm
Hi.. Is your Hotspot Animated...??
coccoce
Re: Custom Hot Spot
by coccoce » Fri Sep 01, 2017 12:12 am
Hello - yes my hot spot is animated. I have laid it out in sequence.
If you want i can send to you to verify.
Re: Custom Hot Spot
by Destiny » Fri Sep 01, 2017 1:30 am
Just attach to a PM... If done right, your hots spot image should be in the Library.. You might need to turn off and restart...
Re: Custom Hot Spot
by Annis » Mon Sep 04, 2017 2:15 pm
Have you restarted Panotour after adding it to your directory?
Can you share the hotspot?
