Zoom transitions missing in VR-Mode
mykill
Likes: 4 posts
by mykill » Wed Aug 02, 2017 2:21 pm
Dear Forum,
I just built a Panotour for an HTC-Vive-Setup. So far it works fine, except for the "zoom to spot" transitions I selected from the actions-parameter menu. As soon as I change to the ?vr-mode to get the whole thing on the Vive the images change only via simple fading and without the zoom-in feature.
Does anybody have a hint or workaround how to fix this?
Thanks, best regards,
Michael
Re: Zoom transitions missing in VR-Mode
by Annis » Mon Aug 07, 2017 8:16 am
There are no such transitions in VR Mode.
mykill
Likes: 4 posts
by mykill » Mon Aug 07, 2017 9:03 am
Hello Annis
and thanks for the welcome and your reply.
The only question that would still remain on my side is why it is not possible. The simple blend transition seems to work also in vr-mode.
by Annis » Mon Aug 07, 2017 11:54 am
All features unsupported by VR Mode are removed in that mode, so that transition is likely part of the unsupported features.
