Custom view doesn't work in 2.5.8
virtualdiorama
Likes: 3 posts
by virtualdiorama » Mon Jul 03, 2017 12:36 pm
Hi guys.
Just upgraded to the new version (2.5.8) and at the same time I couldn't choose the custom view of the panorama anymore.
See video attached. Any ideas anyone?!
Best regards
j.
example2.mov
example
(15.81 MiB) Downloaded 288 times
Johannes Söderström
johannes.soderstrom@virtualdiorama.com
virtualdiorama.com
virtualdiorama
Likes: 3 posts
Re: Custom view doesn't work
by virtualdiorama » Tue Jul 04, 2017 10:46 am
Anyone? Is it only me or did somebody else have the same problem?
Johannes Söderström
virtualdiorama.com
timographie
by timographie » Wed Jul 05, 2017 11:14 am
I also have the same problem since I upgrade to 2.5.8
virtualdiorama
Likes: 3 posts
by virtualdiorama » Wed Jul 05, 2017 11:18 am
Great, im not alone!
I tried to download the old version 2.5.6 and instal it but when I open the panotour pro its still the latest version, how do I downgrade?
Johannes Söderström
virtualdiorama.com
by Destiny » Wed Jul 05, 2017 1:28 pm
Hi.. When you mean Custom View, do you mean Set Default View..??
virtualdiorama
Likes: 3 posts
by virtualdiorama » Wed Jul 05, 2017 1:41 pm
Hi Destiny
On go to a panorama or a group in target view, custom view.
Did you see my video?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Destiny » Wed Jul 05, 2017 10:02 pm
Hi.. I tried to play the vide but it did not work.. I will try it in another player...
by Destiny » Wed Jul 05, 2017 10:19 pm
Hi.. OK, seen the video.. It works in 2.3... Not sure why it fails to work in that window now.. It works OK in the Tour build...
virtualdiorama
Likes: 3 posts
by virtualdiorama » Thu Jul 06, 2017 9:01 am
Ok, thanks for your respons Destiny, but does someone have solution for this problem?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Destiny » Thu Jul 06, 2017 9:04 am
Kolor has only just some on, so they might respond soon.. Annis should be around soon too...
Seems it might be a little bug...
virtualdiorama
Likes: 3 posts
by virtualdiorama » Thu Jul 06, 2017 9:06 am
ok, thanks
Johannes Söderström
virtualdiorama.com
virtualdiorama
Likes: 3 posts
by virtualdiorama » Fri Jul 07, 2017 8:30 am
Hi
Anything new?
Clients are waiting...how do I downgrade to to previous version?
I got the link and the file but when I run it, nothing is happening. Do I need to reinstall the software from the beginning?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Destiny » Fri Jul 07, 2017 8:39 am
Hi.. Sorry for your issues.. The end results will still work as per normal as I tested.. Its just the GUI that has issues..
Yesterday I sent an email to Gerald to check into this issue.. He might be very busy or not in his office.. He is the guy to ask about this. Kolor have changed so much since GoPro bought them, its hard to know what's happening anymore... Not sure where Annis is..
virtualdiorama
Likes: 3 posts
by virtualdiorama » Fri Jul 07, 2017 9:09 am
Yes, it works.
But its still a problem.
Thanks Destiny anyway.
Best regards
j.
Johannes Söderström
virtualdiorama.com
by benji33 » Fri Jul 07, 2017 9:43 am
Thanks for this report,
It's only a GUI issue, the result is correct and custom view is saved into the kpt, on the preview renderer, probably due to our task to optimize the GL rendering into this view.
This issue has been added to our backlog with high priority.
Thanks again for your feedback :)
virtualdiorama
Likes: 3 posts
by virtualdiorama » Mon Jul 17, 2017 10:53 pm
Any idea Benjamin how soon this will work again?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Annis » Tue Jul 18, 2017 1:34 pm
We don't have an ETA for the next bug fix version, if this is a very blocking point for you, I'd recommend using the previous version until a new version is available.
http://www.kolor.com/download-previous-versions/
virtualdiorama
Likes: 3 posts
by virtualdiorama » Tue Jul 18, 2017 1:41 pm
Ok, thanks Annis for fast reply. Do I need to delete the current version 2.5.8 from my computer to be able to instal the previous one.
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Annis » Tue Jul 18, 2017 1:46 pm
No but it's likely that 2.5.7 will install separately instead of replacing, so it depends on whether you want both versions on your computer or not.
virtualdiorama
Likes: 3 posts
by virtualdiorama » Mon Aug 07, 2017 7:46 am
Hello Guys
I´ve tried several times to install earlier versions of Panotour on my MacBook Pro but when I open the software its always 2.5.8. When I install a previous versions, where do I find it?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Annis » Mon Aug 07, 2017 9:58 am
It'll be on your computer, but install separately. Check your apps.
virtualdiorama
Likes: 3 posts
by virtualdiorama » Mon Aug 07, 2017 11:24 am
Hi Annis, thanks for fast reply.
The problem is that the installation works perfect but the program is missing!
Any ideas why?
Best regards
j.
Johannes Söderström
virtualdiorama.com
by Annis » Mon Aug 07, 2017 11:53 am
If the installation was successful then it is somewhere on your computer, likely in your apps you should have several PTP icons.
virtualdiorama
Likes: 3 posts
by virtualdiorama » Fri Sep 01, 2017 3:44 pm
Hi guys
Back to the same question:
Do you know when the new update will arrive because I cant still instal the 2.5.7 version. There is only one PT in my application folder after I tried 10 times...
What should I do in your opinion? I takes a lot longer to produce a walk around when you cant see the custom view!
Best regards
johannes
Johannes Söderström
virtualdiorama.com
timographie
by timographie » Fri Sep 01, 2017 3:49 pm
Hi Johannes
I tried the same thing yesterday.
You can rename the PTP file in your application folder. For example panotour 2.5 -> rename in panotour 2.5.8.
Then when you will install the 2.5.7 version, a new icon will be create in your application folder.
Good luck
Tim
