PTP - File Not Found
SBV360VR
by SBV360VR » Fri Apr 07, 2017 8:27 pm
Hello All !
I used to have an old version installed and then purchase it and updated to 2.5.7 but everytime I open PTP a get a File Not Found messsage.
Its related to a Tour I have already deleted. Even if I try to point out to a file with the same filename and click apply, it does not solve the problem.
How can I fix it, because its annoying me.
Re: PTP - File Not Found
by Annis » Wed Apr 12, 2017 12:58 pm
Have you saved any hotspot styles to your spots library?
If you moved any files linked to those spots then you would get the message, so remove it or save it again after changing the location of the file.
SBV360VR likes this post.
