Ver 2.5.7 will not install   [SOLVED] - View the solution
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sun Apr 02, 2017 12:12 am
Hi
Tried downloading ver 2.5.7 three times and will not install. Must be a problem with the file?
Steve
Re: Ver 2.5.7 will not install  [SOLVED]
by Annis » Mon Apr 03, 2017 9:43 am
The download server isn't the best, but if you get that message it means the installer didn't download completely.
Is your forum account email valid? I can send you the installer directly via WeTransfer, just need an e-mail and to know which version you want.
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Tue Apr 04, 2017 12:29 am
Hi Annis
Latest version of Panotour Pro.
Thanks for that
Steve
by Annis » Tue Apr 04, 2017 8:19 am
The files are uploading now, you should get a link in a few minutes.
PS: I've edited your previous post to remove your e-mail, I could have retrieved it from your account. :)
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Wed Apr 05, 2017 7:44 am
Thanks Annis
All OK Now
Steve
Annis likes this post.
