Custom plugin: actionlist inside elementlist
360-compunics-com-ni
Likes: 15 posts
Liked in: 157 posts
by 360-compunics-com-ni » Fri Mar 31, 2017 11:41 pm
In a custom plugin i want to use an actionlist inside an elementlist, but it does not work as expected.
The use case: for a number of user-selectable files the corresponding actions shall be selectable individually (have attached a screenshot for clarification).
The elementlist works fine (numbered 1), and using the actionchooser an individual action can be assigned. But it is not possible to select multiple actions (numbered 2), nothing happens when the "+"-symbol is clicked.
This is the relevant definition:
   <elementlist id="hspotlist" name="tr:Select hotspot images">
          <group id="hspotItem">
                <filechooser id="hspotfile" name="tr:File" default="" filters="images" allowRemote="false" />
     <actionlist id="hspotactions" name="tr:Set the action to be triggered by this hotspot" >
      <actionchooser id="hspotaction" name="tr:Action" description="tr:Actions triggered"/>
     </actionlist>
          </group>
   </elementlist>
And the relevant code:
{% for hspot in p.hspotlist.elements %}
set(thisAction, '{%with hspot.hspotactions.actions as actions%}{% include 'calltemplate.tmpl' %}{%endwith%}');
{% endfor %}
Am i doing something wrong, or is it not possible?
Thanks in advance for your support.
(edited for clarification)
Likes: 13 posts
Liked in: 115 posts
Re: Custom plugin: actionlist inside elementlist
by bdd » Mon Apr 03, 2017 9:33 am
Sorry, you reached a limitation of our plugin parameters mechanism .
We are aware of this limitation, and we hope to find a solution for it in a future version.
It will not be fixed in a fix release, but only in a major release, as it needs a major change in our algorithms and in our graphical library.
360-compunics-com-ni likes this post.
Likes: 15 posts
Liked in: 157 posts
by 360-compunics-com-ni » Mon Apr 03, 2017 3:13 pm
Hello Gérald,
thanks for your answer. It would be nice to have that possibility, although it's not a major issue because the main action works fine.
Greetings from León,
Michael
