Adding albums and links
Scanphoto
by Scanphoto » Thu Mar 09, 2017 12:29 am
Hi. Tried to add albums to my panorama to make interactive.
Added the gallery from the Plug ins library.
Create a point and added an image to the point. Linked that to the gallery.
Repeated this for the next albums.
In the PTV window. when clicking on the icon. I get the same album for all the different icon.
Have a feeling I done this the wrong way. Can some one help me with the proper workflow.
Really need to get this sorted.
Kind regards
Jonas :)
Re: Adding albums and links
by Destiny » Thu Mar 09, 2017 1:54 am
Hi.. I have just tested that and found PTP exporting as a PTV works fine..
What I suggest you make sure of, for each Gallery it seems you have added a new Gallery, this is correct.. But... Did you assign the hotspot to the right Gallery..?? I suggest you name your Galleries, 1, 2, 3 etc, and then name your hotspots 1, 2, 3.. Then make sure you assign each hotspot to the right Gallery...
Scanphoto
by Scanphoto » Thu Mar 09, 2017 9:26 am
Hi Destiny.
Yepp added the link to the right gallery. That is whats baffles me that they all ended up with the same gallery when the preview was created. I have fairly large pictures, 16x24 cm at 300DPI. Any recommended size for a picture regarding dimensions and resolution(dpi)?
Jonas
by Destiny » Thu Mar 09, 2017 9:58 am
Hi.. You certainly do not use 300 dpi on the web and the actual size of the image are way too big too.... You only need 72 at 80%... 300 dpi is for print..
Not sure why you have having the issue you are.. Annis might have an answer..
by Annis » Thu Mar 09, 2017 11:37 am
Can you upload the tour and share the link? (by PM if need be)
If you view the tour from Panotour (View last built tour button) are the links correct?
Can you send me screenshots of your setup of your different hotspot styles and galleries? So that I can reproduce that part of your project on my side.
