"Encrypt xml files" BUG   [SOLVED] - View the solution
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Tue Mar 07, 2017 3:52 pm
Dashan
eMail: 446426990@qq.com dspano@live.cn
Re: "Encrypt xml files" BUG  [SOLVED]
by Annis » Tue Mar 07, 2017 4:12 pm
Are you using the latest version?
I'd have thought it would be related to the issue 0005866 from the changelog that was fixed in 2.5.6:
0005866: [Tour] VR settings : titles are not displayed in tours generated in trial mode
In trial mode the xml is automatically encrypted, so it should be the same issue.
Anyway, if it doesn't work, in the mean time you can use the krpano encryption tools to encrypt your xml (except the messages xml). Just make sure to uncheck "Use private encryption" in the krpano tools.
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Thu Mar 09, 2017 2:53 am
Hi Annis
yes, Version is 2.5.5, not the trial version .
Dashan
by Annis » Thu Mar 09, 2017 9:19 am
2.5.5 is not the latest version.... So if you're still using the version with the bug there really isn't much I can do to help you.
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Mon Mar 13, 2017 4:57 am
I've upgraded to 2.5. 7, found BUG has been solved, great!
Thanks Annis
Dashan
Annis likes this post.
