Trojan Virus   [SOLVED] - View the solution
RS360VTS
Liked in: 3 posts
Trojan Virus
by RS360VTS » Mon Feb 27, 2017 2:35 pm
I have tried to load and run Panotour 2.5.6 and now the latest 2.5.7 on my pc.
The programme runs, but Kaspersky Total Security blocks, then deletes the Kolor programme as it believes it displays tendancy for a Trojan Virus.
Has anyone else had this problem?
If I go back to Panotour 2.5.5 it works ok.
Any Ideas?
Re: Trojan Virus
by Annis » Mon Feb 27, 2017 3:04 pm
RS360VTS
Liked in: 3 posts
Re: Trojan Virus
by RS360VTS » Mon Feb 27, 2017 3:31 pm
Thanks Annis, I didnt think I would be the only one.
I have submitted a FalsePositive to Kaspersky.
Annis likes this post.
Propigi
Re: Trojan Virus
by Propigi » Tue Feb 28, 2017 4:47 pm
Kaspersky knows the problem.
This is located in the PDM module.
A brief should solve the problem as has been fixed in Panotour Pro 2.5.6.
Propigi
Re: Trojan Virus  [SOLVED]
by Propigi » Thu Mar 02, 2017 9:37 pm
Kaspersky has finally solved this problem for Panotour version 2.5.7
