URGENT: iControl Bar multiple instances bug since v 2.5.6
mompl
by mompl » Mon Feb 27, 2017 7:46 am
Dear all,
Please read update at the end of the post!!
I need your help quite urgently.
Suddenly I am facing the issue, that I have several instances of the iControl bar and Panotour Pro does not allow me to define different buttons per instance,
I have now two instances of a iControl Bar (Control Bar 1 & Control Bar 2)
Let's assume I want to have the "Zoom" button only on Control Bar 1:
Control Bar 1 Zoom
Then I deselect the "Zoom" button on Control Bar 2:
Control Bar 2 no Zoom
Once I switch back to Control Bar 1, the "Zoom" button is also disabled.
Control Bar 1 also no Zoom
This means I cannot have multiple instances of the iControl Bar with individual buttons.
Interestingly this function worked just fine before and suddenly stopped.
This is mandatory for my client and I am stuck right now.
Please, any help / solution is very appreciated!!
Thank you sooo much.
UPDATE:
I did some back and forth installation and I figured out that the bug appears first time with version 2.5.6.
Version 2.5.5 works just nice as expected.
Re: URGENT: iControl Bar multiple instances bug since v 2.5.
by Annis » Mon Feb 27, 2017 3:34 pm
Have you built the tour inbetween editing the buttons of each control bar? (Meaning it could just be a visual issue in PTP but the built tour works)
Does this happen with any other control bar?
mompl
by mompl » Thu Mar 02, 2017 5:29 am
Annis wrote:Hello and welcome to the forum,
Thank you very much for your quick reply.
I've checked several solutions without any success.
As already mentioned, the error started with version 2.5.6 so I am not sure if Kolor wants to keep that bug from now on.
And no, it is not just a visual issue in PTP. The tour will have two identical control bars as the user is not able to define different buttons for each control bar.
by Destiny » Thu Mar 02, 2017 6:24 am
Hi.. As Annis said, if you close PPT, the Default buttons might display but the build is as you set it... BUT, if you build again after opening, are your menu settings as you want them... I too have questioned if this is a bug or not..
If you edit your menu as you want, and save it as a PreSet of your own, naming it as No Zoom for example, you can call that into your Tours anytime and they should always remain as you set your PreSet.
mompl
by mompl » Thu Mar 02, 2017 7:47 am
As I said, the build is NOT as I set it.
If I define the buttons of one bar, the other will change instantly.
Therefore I can't really set a preset as I can't define two bars with different buttons.
The buttons of all bars will always be the same.
I don't quite get it why there should be a work around (which isn't a work around as it won't work either) for something which worked just fine before.
A bug is a bug is a bug. :-)
Anyway. I am using version 2.5.5 until it's fixed ... if it ever will be fixed.
mompl
by mompl » Thu Mar 02, 2017 8:03 am
iControl bug.mp4
iControl bug screen capture
(6.24 MiB) Downloaded 17 times
by Destiny » Thu Mar 02, 2017 8:50 am
Yes, I see what you mean, but what happens AFTER you have built the Tour.. Flipping back and forth between two menus, to me will suggest that the menu default kicks in... What happens if you edit one menu, edit the second menue then Build.. Do the menu's still flip back to the default..
I do get what you are suggesting.. And you are right it should remain as you set it... But untill it has been used at the setting you have set it to, to me logically it will flip back to the default, then it should remain as you have set it..
by Annis » Thu Mar 02, 2017 9:13 am
Thanks for the video, however you didn't show if, after building (even with PTP's interface telling you otherwise) if the iControls bar have their different buttons.
In my test, there definitely is a visual issue in PTP, but each control bar had their own buttons in the built tour, which is why I need you to confirm or deny you also have this behaviour.
In either case it is a bug that will be opened.
