Panotour Pro Crashes After Patch Update   [SOLVED] - View the solution
hnerenberg
by hnerenberg » Wed Feb 22, 2017 9:35 pm
Several days ago I installed the latest patch, (PanotourProMac256_2017-02-07). However, following the install when I open an existing project and I select some or all of the panoramas and delete them, the program crashes. The only work around that I found was that I have to load my new panoramas and then delete the old panoramas, one by one. No good. As a reference, I am running a late 2013 iMac and OS 10.11.6 and 8 GB RAM. Is there a fix to this bug?
Re: Panotour Pro Crashes After Patch Update  [SOLVED]
by Annis » Mon Feb 27, 2017 3:19 pm
Download and install PTP 2.5.7 that fixes this bug.
http://www.kolor.com/download/
