VR Menu Facility
view360
Liked in: 3 posts
VR Menu Facility
by view360 » Tue Feb 21, 2017 10:21 pm
Evening All, is anyone able to help me create a 'Menu' in a VR tour. Currently I can only access area to area (room to room) using the Point Spot Style, where I use an arrow. This is okay for a property, when one room naturally leads to another but not so good when you want to showcase a facility, where the layout does not flow.
Thanks in advance. John@View360.
Re: VR Menu Facility
by Annis » Mon Feb 27, 2017 2:19 pm
You could either set up one dummy scene with thumbnails to each of your panoramas/groups or a scene with floorplans as part of the image and use that to navigate.
You could then access this scene using the VR Mode - Nadir/Zenith Home button
view360
Liked in: 3 posts
by view360 » Mon Feb 27, 2017 2:26 pm
Hi Annis, that's exactly what I did - http://www.view360online.co.uk/Client/A ... index.html
Would appreciate your feedback.
Regards, John
