Web Content Spot works offline, but not online??   [SOLVED] - View the solution
vitodivita
by vitodivita » Thu Feb 16, 2017 11:05 pm
Help please. Embedded a web page into a tour I'm doing, and it works fine offline both in Preview in Panotour as well as going to the HTML file. Online, none of the pages load, they are black. What am I doing wrong??
Re: Web Content Spot works offline, but not online??
by Destiny » Thu Feb 16, 2017 11:27 pm
Hi... You probably need to provide the full url.... Online it will find it but off line it will not have clue where it is.... Unless you provide the full url address...
vitodivita
by vitodivita » Thu Feb 16, 2017 11:37 pm
It works fine offline. Online it doesnt. I put the full URL down to the HTML file
vitodivita
Here's the code that comes out of Panotour
by Destiny » Thu Feb 16, 2017 11:43 pm
iFrame needs a suffix of html...
PS.. I tested the url.. It's an incorrect url..
vitodivita
by vitodivita » Thu Feb 16, 2017 11:48 pm
Same issue
Here's the tour in question. Pan over to the left you'll see black box..
https://360revo.com/chicagoautoshownew/
How is the URL incorrect? Works offline fine? I've seen what it does when URL is wrong (black box). But in this case its saying all of them are wrong
by Destiny » Fri Feb 17, 2017 1:38 am
Well.. with the index.html the url is now complete, but still will not display in a Tour.. It might be a permissions thing.. Where you have uploaded the car, right mouse on the folder and check to make sure it has all the read and rights ticked.
http://www.destinyvirtualtours.com/test ... /Test.html
http://www.360ext.com/cas17/acuramdxext/index.html
Other than that.. I do no know.. The car will not open in a website box either.. So I would suggest it might have something to do with permissions. The server will not allow you access to it..
vitodivita
by vitodivita » Fri Feb 17, 2017 1:53 am
All permissions look fine. We use this server daily to no issue.
vitodivita
by vitodivita » Fri Feb 17, 2017 2:00 am
I can't even explain it, but all I did was change the URL to my website 360revo.com, and then changed it back, and now all the web content spots are working…. Thank you?!
I'm noticing this doesn't work on iOS? Is this only a desktop based feature?
by Destiny » Fri Feb 17, 2017 2:11 am
I don't know. I would have that thought it would still work with iOS.. It looks like you have used Object2VR to rotate the car.. Did you save as a html5.. Does this work in iOS.. http://www.destinyvirtualtours.com/Obje ... gClip.html
vitodivita
by vitodivita » Fri Feb 17, 2017 2:18 am
Yes that loaded fine. We use Object2VR daily, it always works on the mobile devices for us, but in this particular tour, it doesn't even load. The code in the XML says HTML5.noIOS, is it saying it won't show on iOS?
by Destiny » Fri Feb 17, 2017 2:26 am
Gerald will know or Annis.. They will not be around for a few hours though..
vitodivita
by vitodivita » Fri Feb 17, 2017 2:27 am
Okay good to know. Appreciate the help so far. It's a very cool feature I would love to make this work..
Re: Web Content Spot works offline, but not online??  [SOLVED]
by Annis » Fri Feb 17, 2017 9:13 am
The issue is the http/https conflict. Your website is in https, the website you are trying to display in an iFrame is http which is considered a security issue and as such is blocked by the browser.
This conflict can also happen in the opposite situation (https displayed on http).
vitodivita
by vitodivita » Fri Feb 17, 2017 4:31 pm
That fixed it on the desktop.
I am still getting blank on the iOS devices. I put in a plain website and it still doesn't appear.
by Annis » Fri Feb 17, 2017 4:41 pm
In your link I'm still seeing the http/https concurrency, Did you update the tour?
vitodivita
by vitodivita » Fri Feb 17, 2017 5:30 pm
Okay I just updated tour so now every link is HTTPS. I still do not see anything on mobile.
by Destiny » Fri Feb 17, 2017 6:39 pm
Its the S in the url which is the issue.. You cannot have https..
vitodivita
by vitodivita » Fri Feb 17, 2017 6:47 pm
I'll put the tour on my other server, since 360revo.com is an https: domain. Are you saying this is the reason it won't work on mobile? Because desktop works fine.
vitodivita
by vitodivita » Fri Feb 17, 2017 8:37 pm
by Destiny » Fri Feb 17, 2017 9:26 pm
Having a https is a security feature.... Websites like Google cannot be viewed using Website Box and I think iFrames too... https://www.google.com.au
Your web page seems to be working my end.. You might need to empty your cache folder.....
vitodivita
by vitodivita » Fri Feb 17, 2017 11:43 pm
Works as it should on desktop, but not on mobile devices. Nothing shows, not even a black box
by Destiny » Sat Feb 18, 2017 1:46 am
Works on my Tablet..
Destiny....
by Destiny » Sun Feb 19, 2017 10:56 am
If you have issues with Object2VR, you might want to take a look at Zoomify.. Here is a link to a car but I made far too many images. I should have cut it down to a max of 36, but here there are 100. Makes loading a bit slow..
http://members.westnet.com.au/dps/360Ob ... Car360.htm
There are others too.. I for some reason, have some issues with Object2VR.. Locally it works fine but remotely I have issues.. Today, my skin images are missing. I have used it OK in the past.. I edited the code to provide a full url but its still did not work. I tried using Chrome but same issues. There is no real reason why this should be happening. i will find an older project and test it..
Its easy enough to make some buttons skins for Object2VR, which is a good job too since the default ones are mostly yuck.. The set you are using is the only one that I feel look decent..
