Panotour 2.5 Keeps Closing
ori0n
by ori0n » Thu Feb 16, 2017 12:57 pm
I have just upgraded my panotour from 1.8 to 2.5
I realised that in my 2.5 version it crashes out very easily. I can't even get to maximise my program.
Please kindly advise.
Justin
Re: Panotour 2.5 Keeps Closing
by Annis » Thu Feb 16, 2017 1:03 pm
Have you been able to send in any crash reports?
What is your computer configuration?
mastrom
by mastrom » Thu Feb 16, 2017 10:07 pm
I have the same issue. EVERY TIME I click build the software crashes! Tried both the 32 & 64-bit version and they behave exactly the same! uninstalled and re-installed a number of times and the problem just keep on coming!
by Annis » Fri Feb 17, 2017 9:54 am
Same question mastrom, have you been able to send in crash reports so that I can check them?
I haven't managed to find any with your forum account's e-mail.
What is your full computer config?
Which version of Panotour are you using?
Is this on a new project, one made in an older version of PTP?
mastrom
by mastrom » Fri Feb 17, 2017 6:05 pm
I haven't received any crash-reports. The software just closes. And it's a new project. Bought Panotour yesterday because I was going to use it in my startup but now I'm considering other options, this was just a first test and it didn't go well.
My pc is a win10 64-bit machine,
Intelbased with a intel 6850 cpu, 32gb ddr4 memory and nvidia gtx1070 graphics cards. Running on a Samsung 950 ssd
ori0n
by ori0n » Sat Feb 18, 2017 11:59 am
Annis wrote:Have you been able to send in any crash reports?
Very sorry for the late reply. Yes, during the crashes there was a popup to prompt us to send the information which I did.
My PC configuration:
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60Ghz
Ram: 16GB
System Type: 64 Bit Operating System
OS: Windows 10 Pro
If you need any other information please feel free to ask.
Thank you for your attention in advance!
ori0n
by ori0n » Sat Feb 18, 2017 12:01 pm
Also I have my old 1.8 version still installed in the PC. Just FYI.
zachmwas
by zachmwas » Sun Feb 19, 2017 6:46 am
I have the same issue of crashing everty time I try to start the programme, although I was running the a trial version. I thought of installing it on a different machine only for it not to load the panoroma, nothing happens. Its like I never added any panoroma images. It shows its loading upto 100% then nothing.
by Annis » Mon Feb 20, 2017 4:31 pm
zachmwas wrote:I have the same issue of crashing everty time I try to start the programme, although I was running the a trial version. I thought of installing it on a different machine only for it not to load the panoroma, nothing happens. Its like I never added any panoroma images. It shows its loading upto 100% then nothing.
Have you been able to send in a crash report with your e-mail so that I can look it up?
by Annis » Mon Feb 20, 2017 4:33 pm
Ram: 16GB
OS: Windows 10 Pro
What is your graphics card, and are the drivers up to date?
I found your crash reports except that they're... empty.
Do any previous versions have this issue? Like 2.5.5, 2.5.4 ?
You can download those here: http://www.kolor.com/download-previous-versions/
ori0n
by ori0n » Mon Feb 20, 2017 4:36 pm
Ram: 16GB
OS: Windows 10 Pro
Hi
thank you for your reply. I will try the older versions to see if there are any problems.
As for my video cards they are okay, pretty mid level radeon video card
by Annis » Mon Feb 20, 2017 4:43 pm
Okay or not, is the driver up to date? What card is it and what is the driver version?
edgar_ali
Liked in: 3 posts
by edgar_ali » Tue Feb 21, 2017 1:42 am
My Panotour is crashing when I try to delete a panorama or a group of panorama...
I just recently upgrade my panotour version to 2.5.6 64 bits...
My computer is a iMac running in macOS Sierra
Can you help?...
I have been uploading the crashing reports and writing in the comments that it crash as soon as i try to delete a photo or a group...
Please help
ori0n
by ori0n » Tue Feb 21, 2017 11:47 am
Annis wrote:Okay or not, is the driver up to date? What card is it and what is the driver version?
Hi Annis,
I rolled back to 2.5.5 and its working :) Thanks!!
by Annis » Tue Feb 21, 2017 5:18 pm
edgar_ali wrote:My Panotour is crashing when I try to delete a panorama or a group of panorama...
Can you help?...
Please help
There is an open bug on Mac for crashes when removing scenes.
Can you use any previous versions?
edgar_ali
Liked in: 3 posts
by edgar_ali » Wed Feb 22, 2017 1:36 am
I think I have I will have to go back to the previous version...I will try later today and confirm
mastrom
by mastrom » Fri Feb 24, 2017 3:47 pm
It still doesnet work for me! How do I get my money back??
edgar_ali
Liked in: 3 posts
by edgar_ali » Sat Feb 25, 2017 9:25 pm
I rolled back and it is working for me now...
by Annis » Mon Feb 27, 2017 5:26 pm
@edgar_ali, if you haven't already, download PTP 2.5.7 which solves the bug you were having on Mac.
@mastrom, I still don't have any crash reports from you.
Do you have any Lavasoft malware on your computer? (Even remains)
Do you have any manufacturer pre-installed applications like Dell Backup and recovery tool, MSI Nahimic, or others?
mastrom
by mastrom » Mon Feb 27, 2017 6:51 pm
I didn't receive any crash reports. Please advice me on where to find these?
And no on all your other questions.
by Annis » Tue Feb 28, 2017 9:57 am
When the software crashes, this window pops up.
Make sure that your e-mail is in the window, and click on upload.
Without a crash report, I can't tell you why the crash is happening, since from your symptoms it would be Lavasoft or some similar malware causing issues with PTP.
mastrom
by mastrom » Tue Feb 28, 2017 11:07 am
Annis wrote:When the software crashes, this window pops up.
No, this window doesn't show up. The software just close down.
gholder26
by gholder26 » Sun Mar 05, 2017 3:16 am
Annis wrote:@edgar_ali, if you haven't already, download PTP 2.5.7 which solves the bug you were having on Mac.
My Mac still crashes with 2.5.7
by Annis » Tue Mar 07, 2017 9:31 am
I will have to lock this thread, it keeps getting hijacked by unrelated crashes (but nonetheless serious), making it impossible manage the posted issues. Anyone with crashes, please make sure you create a new topic with details, and if you can send in a crash report with your e-mail address so that it can be found!
@gholder26, I need you to create a new topic with your issue, and provide additional information:
The crash seems to occur managing the "memory" for a scene, when Panotour creates cache files to handle the image and any changes. This could happen if your image is corrupted (and as such not supported by the software's internal libraries) or if your disk has issues like no more free space for example.
1) When exactly does the crash happen? As soon as you select a scene?
2) Does it crash with any image or one or some particular ones? If one or several particular ones, what are they/can you zip some and share them?
3) Is your Temp folder full? Could you try assigning a Temp folder specific for PTP from the software settings?
@mastrom, Did you do an in-depth search for Lavasoft components? Even after an uninstall of such malware, some components can remain.
