Panotour 2.5.6 win -> trojan virus?   [SOLVED] - View the solution
Redmar
by Redmar » Mon Feb 13, 2017 2:51 pm
While using the new Panotour version Kaspersky found a PDM:Trojan.Win32.Generic virus in Panotour.exe. After disinfecting the .exe file is deleted. We downloaded the version from the Kolor site last week. Looking forward to your response.
Re: Panotour 2.5.6 win -> trojan virus?  [SOLVED]
by Annis » Mon Feb 13, 2017 2:54 pm
It's a false positive. https://support.kaspersky.com/viruses/general/1870
I can assure you that there are no viruses in our software, that would be a lousy feature.
Redmar
by Redmar » Mon Feb 13, 2017 3:05 pm
Thanks, we'll look into it. Pehaps you can submit this to Kaspersky to prevent future problems with other clients?
by Annis » Mon Feb 13, 2017 3:14 pm
We have already submitted it as a false positive, you can do the same there is a link on the post I sent you.
Redmar
by Redmar » Mon Feb 13, 2017 3:28 pm
Will do!
Annis likes this post.
